Author: pgf Date: Mon Jul 30 09:12:55 2012 New Revision: 3093 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3093
Log: config ec-flags-offset on a per laptop basis
Modified: cpu/arm/olpc/1.75/config.fth cpu/arm/olpc/cl4/config.fth cpu/arm/olpc/edi.fth
Modified: cpu/arm/olpc/1.75/config.fth ============================================================================== --- cpu/arm/olpc/1.75/config.fth Mon Jul 30 09:12:43 2012 (r3092) +++ cpu/arm/olpc/1.75/config.fth Mon Jul 30 09:12:55 2012 (r3093) @@ -29,7 +29,8 @@ d# 9999 constant machine-type \ Backwards compatibility with non-device-tree kernel
char 4 constant expected-ec-version -h# 8000 value /ec-flash +h# 8000 constant /ec-flash +h# 7e80 constant ec-flags-offset \ don't program or verify this page
\ These constants are correct for XO-1.75 and XO-CL4; they might \ need to be changed for different hardware. See setup-gpios-hack
Modified: cpu/arm/olpc/cl4/config.fth ============================================================================== --- cpu/arm/olpc/cl4/config.fth Mon Jul 30 09:12:43 2012 (r3092) +++ cpu/arm/olpc/cl4/config.fth Mon Jul 30 09:12:55 2012 (r3093) @@ -25,7 +25,8 @@ d# 10001 constant machine-type \ Backwards compatibility with non-device-tree kernel
char 5 constant expected-ec-version -h# 10000 value /ec-flash +h# ec00 constant /ec-flash +h# eb80 constant ec-flags-offset \ don't program or verify this page
fload ${BP}/cpu/arm/mmp3/soc-config.fth
Modified: cpu/arm/olpc/edi.fth ============================================================================== --- cpu/arm/olpc/edi.fth Mon Jul 30 09:12:43 2012 (r3092) +++ cpu/arm/olpc/edi.fth Mon Jul 30 09:12:55 2012 (r3093) @@ -191,7 +191,7 @@ h# 70 flash-cmd ( ) \ Program page command wait-flash-busy ( ) ; -h# 7e80 constant ec-flags-offset + : edi-program-flash ( adr len offset -- ) cr ( adr len offset ) swap 0 ?do ( adr offset )
