Author: wmb Date: Tue Jul 3 08:28:56 2012 New Revision: 3035 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3035
Log: OLPC XO-1.75 - support new EC version.
Modified: cpu/arm/olpc/build-fw.fth cpu/arm/olpc/ecflash.fth
Modified: cpu/arm/olpc/build-fw.fth ============================================================================== --- cpu/arm/olpc/build-fw.fth Tue Jul 3 08:19:40 2012 (r3034) +++ cpu/arm/olpc/build-fw.fth Tue Jul 3 08:28:56 2012 (r3035) @@ -197,6 +197,19 @@
load-base constant flash-buf
+ +[ifdef] cl2-a1 +h# 10000 value /ec-flash +char 3 value expected-ec-version +[else] +h# 8000 value /ec-flash +: clx-touch? ( -- ) board-revision h# 3a18 >= ; ++ olpc-cl2 : expected-ec-version clx-touch? if [char] 6 else [char] 4 then ; ++ olpc-cl3 char 5 value expected-ec-version +[then] + +[ifndef] cl2-a1 +[then] fload ${BP}/cpu/arm/olpc/ecflash.fth
: ec-spi-reprogrammed ( -- ) @@ -340,7 +353,6 @@ fload ${BP}/cpu/arm/olpc/sdhci.fth
[ifndef] cl2-a1 -: clx-touch? ( -- ) board-revision h# 3a18 >= ; : boot-dev-gpio# ( -- n ) clx-touch? if 2 else d# 56 then ; fload ${BP}/cpu/arm/olpc/emmc.fth [then]
Modified: cpu/arm/olpc/ecflash.fth ============================================================================== --- cpu/arm/olpc/ecflash.fth Tue Jul 3 08:19:40 2012 (r3034) +++ cpu/arm/olpc/ecflash.fth Tue Jul 3 08:28:56 2012 (r3035) @@ -1,16 +1,6 @@ \ See license at end of file purpose: Reflash the EC code
- -[ifdef] cl2-a1 -h# 10000 value /ec-flash -char 3 value expected-ec-version -[else] -h# 8000 value /ec-flash -+ olpc-cl2 char 4 value expected-ec-version -+ olpc-cl3 char 5 value expected-ec-version -[then] - : check-signature ( adr -- ) /ec-flash + h# 100 - ( adr' ) dup " XO-EC" comp abort" Bad signature in EC image" ( adr )
