Author: wmb Date: 2009-12-09 16:04:23 +0100 (Wed, 09 Dec 2009) New Revision: 1560
Added: cpu/x86/pc/olpc/via/initsmt.fth Modified: cpu/x86/pc/olpc/via/smttags.fth Log: New version of smttags.fth
Added: cpu/x86/pc/olpc/via/initsmt.fth =================================================================== --- cpu/x86/pc/olpc/via/initsmt.fth (rev 0) +++ cpu/x86/pc/olpc/via/initsmt.fth 2009-12-09 15:04:23 UTC (rev 1560) @@ -0,0 +1,12 @@ +\ Inject some tag values to get the manufacturing process started +: no-restart ( -- ) no-kbc-reboot kbc-on d# 300 ms ; +patch no-restart io-spi-reprogrammed io-spi-start + +h# 202 msr@ swap h# ff invert and swap h# 202 msr! \ Uncache flash + +add-tag TS SMT +add-tag MS cifs:\bekins:bekind2@10.60.0.2\nb2_fvs +add-tag BD u:\boot\olpc.fth cifs:\bekins:bekind2@10.60.0.2\nb2_fvs\olpc.fth +add-tag NT 10.60.0.2" evaluate + +.( Wrote TS, MS, BD, and NT) cr
Modified: cpu/x86/pc/olpc/via/smttags.fth =================================================================== --- cpu/x86/pc/olpc/via/smttags.fth 2009-12-09 15:03:46 UTC (rev 1559) +++ cpu/x86/pc/olpc/via/smttags.fth 2009-12-09 15:04:23 UTC (rev 1560) @@ -1,15 +1,11 @@ \ SMT test
-\ visible +visible
-\ This is for testing, until we get the MS tag injected into the final image -[ifdef] factory-server$ -: set-server ( -- ) - factory-server$ nip 0= if - " cifs:\bekins:bekind2@10.60.0.2\nb2_fvs" to factory-server$ - then +: mfg-ntp-server ( -- name$ ) + " NT" find-tag if ?-null else " 10.60.0.2" then ; -[then] +' mfg-ntp-server to ntp-servers
: .instructions ( adr len -- ) cr blue-letters type black-letters cr @@ -19,7 +15,7 @@ ;
d# 20 buffer: bn-buf \ Buffer for scanned-in board number string -: scanned-board#$ ( -- adr len ) bn-buf count ; +: board#$ ( -- adr len ) bn-buf count ;
: accept-to-buf ( buf len -- actual ) over 1+ swap accept ( buf actual ) @@ -34,7 +30,7 @@ " Please Input Board Number ......" .instructions bn-buf d# 20 accept-to-buf ( n ) d# 14 <> if - " Wrong length, try again" .problem + " Wrong length (must be 14 characters), try again" .problem else bn-buf 1+ c@ [char] Q = if exit then " Must begin with Q, try again" .problem @@ -43,7 +39,7 @@ ;
d# 20 buffer: station#-buf -: station#$ ( -- adr len ) station#-buf count ; \ e.g. 01 +: station#$ ( -- adr len ) station#-buf count ; \ e.g. J01
: get-station# ( -- ) ." *****" @@ -51,14 +47,11 @@ " Please Input Station Number ......" .instructions
station#-buf d# 20 accept-to-buf ( n ) - d# 2 <> if - " Wrong length, try again" .problem + d# 3 <> if + " Wrong length (must be like J01), try again" .problem else - station#$ push-decimal $number pop-base if ( ) - " Must be a number, try again" .problem - else ( n ) - drop exit - then + station#-buf 1+ c@ [char] A [char] Z between if exit then + " Must begin with A-Z, try again" .problem then again ; @@ -70,13 +63,16 @@ : get-opid ( -- ) ." *****" begin - " Please Operator ID ......" .instructions + " Please Input Operator ID ......" .instructions opid-buf d# 20 accept-to-buf ( n ) - d# 4 <> if - " Wrong length, try again" .problem + d# 8 <> if + " Wrong length (must be 8 digits), try again" .problem else - opid-buf 1+ c@ [char] A = if exit then - " Must begin with A, try again" .problem + opid$ push-decimal $number pop-base if ( ) + " Must be a number, try again" .problem + else ( n ) + drop exit + then then again ; @@ -85,7 +81,7 @@ d# 20 buffer: filename-buf : smt-filename$ ( -- ) filename-buf count ; : set-filename ( -- ) - scanned-board#$ filename-buf place + board#$ filename-buf place " .txt" filename-buf $cat ;
@@ -97,21 +93,21 @@ ;
\ Upload the result data -: smt-result ( pass? -- adr len ) +: smt-result ( pass? -- ) smt-filename$ open-temp-file if " PASS" else " FAIL" then " RESULT=" put-key+value " PROCESS=FVT" put-key-line " STATION=" put-key-line " OPID=" put-key-line " GUID=" put-key-line - scanned-board#$ " MB_NUM=" put-key+value + board#$ " MB_NUM=" put-key+value " Result" submit-file ;
\ Send the board number as the request and return the response data : smt-request$ ( -- adr len ) smt-filename$ open-temp-file - scanned-board#$ " MB_NUM=" put-key+value + board#$ " MB_NUM=" put-key+value opid$ " OPID=" put-key+value station#$ " STATION=" put-key+value " Request" submit-file @@ -125,19 +121,57 @@ ($add-tag) ( ) ;
+\ Remove possible trailing carriage return from the line +: ?remove-cr ( adr len -- adr len' ) + dup if ( adr len ) + 2dup + 1- c@ carret = if ( adr len ) + 1- + then + then +; + +: put-tag ( value$ key$ -- ) + 2swap dup if add-null then 2swap ( value$' key$ ) + ($add-tag) ( ) +; + +0 0 2value response$ + +\ If the server sends us tags in the response file, we put +\ them in the mfg data +: write-new-tags ( adr len -- ) + begin dup while ( adr len ) + linefeed left-parse-string ( rem$ line$ ) + ?remove-cr ( rem$ line$ ) + [char] = left-parse-string ( rem$ value$ key$ ) + dup 2 = if ( rem$ value$ key$ ) + put-tag ( rem$ ) + else ( rem$ value$ key$ ) + 4drop ( rem$ ) + then ( rem$ ) + repeat ( adr len ) + 2drop ( ) +; + \ Decode the server's response and insert appropriate mfg data tags -: parse-smt-response ( adr len -- error? ) - drop " Timeout" comp 0= if true exit then +: parse-smt-response ( -- ) + ." Server responded with: " cr response$ list cr ( )
+ response$ nip 0= if ." Null manufacturing data" cr exit then + +." Type q to skip tag write " key dup emit cr [char] q = if + 2drop false exit +then + flash-write-enable
clear-mfg-buf ( ) -\ XXX propagate tag values from response - code in Notes/mfgtags.fth - " " " ww" put-ascii-tag ( ) - " EN" " SS" put-ascii-tag ( ) - " ASSY" " TS" put-ascii-tag ( ) - " C1" " SG" put-ascii-tag ( ) - scanned-board#$ " B#" put-ascii-tag ( ) + response$ write-new-tags ( ) +\ " " " ww" put-ascii-tag ( ) +\ " EN" " SS" put-ascii-tag ( ) +\ " ASSY" " TS" put-ascii-tag ( ) +\ " D3" " SG" put-ascii-tag ( ) +\ board#$ " B#" put-ascii-tag ( ) (put-mfg-data) ( )
\ check-tags @@ -148,114 +182,109 @@ false ;
-\ Perform the exchange with the manufacturing server -: smt-tag-exchange ( -- error? ) - smt-request$ ( adr len ) - 2>r 2r@ parse-smt-response ( error? r: adr len ) - 2r> free-mem ( error? ) -; - -d# 15 to #mfgtests - -: smt-tests ( -- pass? ) - 5 #mfgtests + 5 do - i set-current-sq - refresh - d# 200 0 do - d# 10 ms key? if unloop unloop exit then - loop - doit - pass? 0= if unloop false exit then - loop - all-tests-passed - true -; - -0 value usb-ih -: open-usb ( -- ) - " /usb:noprobe" open-dev to usb-ih - usb-ih 0= abort" Can't open USB!" -; -: close-usb ( -- ) usb-ih close-dev 0 to usb-ih ; : silent-probe-usb ( -- ) " /" ['] (probe-usb2) scan-subtree " /" ['] (probe-usb1) scan-subtree report-disk report-net report-keyboard ; -: usb-ports-changed? ( -- flag ) - open-usb - " ports-changed?" usb-ih $call-method ( changed? ) - close-usb -;
-: ?reprobe-usb ( -- ) usb-ports-changed? if silent-probe-usb then ; -: reprobe-usb ( -- ) - begin d# 100 ms usb-ports-changed? until - silent-probe-usb -; : scanner? ( -- flag ) " usb-keyboard" expand-alias if 2drop true else false then ; : wait-scanner ( -- ) - begin scanner? 0= while ( ) + scanner? 0= if " Connect USB barcode scanner" .instructions - reprobe-usb - repeat + begin d# 1000 ms silent-probe-usb scanner? until + then ; : wired-lan? ( -- flag ) " /usb/ethernet" locate-device if false else drop true then ; : wait-lan ( -- ) - begin wired-lan? 0= while + wired-lan? 0= if " Connect USB Ethernet Adapter" .instructions - reprobe-usb - repeat + begin d# 1000 ms silent-probe-usb wired-lan? until + then ; : usb-key? ( -- flag ) " /usb/disk" locate-device if false else drop true then ; : wait-usb-key ( -- ) - begin usb-key? 0= while + usb-key? 0= if " Connect USB memory stick" .instructions - reprobe-usb - repeat + begin d# 1000 ms silent-probe-usb usb-key? until + then ; : wait-connections ( -- ) - ?reprobe-usb + silent-probe-usb wait-scanner wait-lan wait-usb-key ;
-: do-smt-test ( -- ) +0 value test-passed? +: show-result-screen ( -- ) + restore-scroller + clear-screen + test-passed? if + ." Selftest passed." cr cr cr + d# 2000 ms + green-screen + else + ." Selftest failed." cr cr cr + d# 2000 ms + red-screen + then +; + +: finish-smt-test ( pass? -- ) + show-result-screen + + cifs-connect + ." Uploading test result " test-passed? smt-result ." Done" cr + cifs-disconnect + + test-passed? if + ." Writing tags " parse-smt-response ." Done" cr + then + + ." Powering off ..." d# 2000 ms + power-off +; + +d# 15 to #mfgtests + +: smt-tests ( -- ) + 5 #mfgtests + 5 do + i set-current-sq + refresh + d# 1000 ms + doit + pass? 0= if false to test-passed? finish-smt-test unloop exit then + loop + true to test-passed? finish-smt-test +; + +\ This modifies the menu to be non-interactive +: doit-once ( -- ) do-key smt-tests ; +patch doit-once do-key menu-interact + +: start-smt-test ( -- ) wait-connections
." Setting clock " ntp-set-clock ." Done" cr
get-info + ." Connecting " cifs-connect ." Done" cr + ." Getting tags from server " smt-request$ to response$ ." Done" cr + cifs-disconnect
- ." Writing mfg data tags " smt-tag-exchange ." Done" cr - - ['] true is (diagnostic-mode?) + true to diag-switch? " patch smt-tests play-item mfgtest-menu" evaluate menu - ['] false is (diagnostic-mode?) - - ." Uploading test result " smt-result ." Done" cr - - cifs-disconnect + false to diag-switch? ;
-\ patch do-smt-test play-item mfgtest-menu - -true value once? -: doit-once ( -- ) - do-key - once? if - false to once? -\ doit - smt-tests - then -; -patch doit-once do-key menu-interact +\ Automatically run the sequence +start-smt-test
