Author: pgf Date: Fri Aug 10 00:25:40 2012 New Revision: 3147 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3147
Log: bsl.fth: don't modify mfp settings on cl4
the pin settings established by cforth are correct on cl4-a2.
Modified: cpu/arm/olpc/bsl.fth
Modified: cpu/arm/olpc/bsl.fth ============================================================================== --- cpu/arm/olpc/bsl.fth Thu Aug 9 22:34:22 2012 (r3146) +++ cpu/arm/olpc/bsl.fth Fri Aug 10 00:25:40 2012 (r3147) @@ -51,9 +51,12 @@ \ The pin setup should be done in CForth, but it's complicated by \ the fact that the touch-enabled CL2 uses GPIO 56 differently from \ the ordinary one -[ifdef] olpc-cl2 3 d# 55 af! 3 d# 56 af! [then] \ Setup pins for UART2 +[ifdef] olpc-cl2 + 3 d# 55 af! \ Setup pins for UART2 + 3 d# 56 af! 0 touch-tck-gpio# af! \ Set to GPIO function 1 touch-rst-gpio# af! \ Set to GPIO function (AF0 is SM_BELn for this pin) +[then] ;
0 [if]
