Author: wmb Date: Wed Aug 1 06:39:11 2012 New Revision: 3107 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3107
Log: ## Lines starting with '## ' will be removed from the log message. ## File(s) to commit recursively: ## cpu/arm/marvell/tim.fth Marvell TIM compiler - fixed misleading name.
Modified: cpu/arm/marvell/tim.fth
Modified: cpu/arm/marvell/tim.fth ============================================================================== --- cpu/arm/marvell/tim.fth Wed Aug 1 06:34:49 2012 (r3106) +++ cpu/arm/marvell/tim.fth Wed Aug 1 06:39:11 2012 (r3107) @@ -1,7 +1,7 @@ : >hex ( n -- n' ) d# 10 /mod h# 10 * + ;
0 value tim-version -: tim-v3? ( -- flag ) tim-version h# 00ffff00 and h# 00030400 = ; +: tim-v4? ( -- flag ) tim-version h# 00ffff00 and h# 00030400 = ;
: today>hex ( -- n ) today ( day month year ) @@ -10,7 +10,7 @@ rot >hex >r ( yr century r: hex-month hex-day ) >hex >r ( yr r: hex-month hex-day hex-century ) >hex r> r> r> - tim-v3? if 2swap then + tim-v4? if 2swap then bljoin ( n ) ;
@@ -129,10 +129,10 @@ over <> abort" Read failed" ( size ) ifd @ fclose ( size ) \ Older BOOTROMs seem to want the size to be strongly aligned - tim-v3? if 4 else h# 800 then round-up ( size' ) + tim-v4? if 4 else h# 800 then round-up ( size' ) ; : place-hash \ XXX need to implement non-null hash info - tim-v3? if + tim-v4? if 0 l, \ Size to hash (should be -1 but 0 is in the examples) d# 20 l, \ HashAlgorithmID - SHA-160 d# 16 0 do 0 l, loop \ Hash
