Author: wmb Date: Thu Aug 9 14:28:19 2012 New Revision: 3144 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3144
Log: OLPC CL4 - added some MMP3-specific entries to the list of clock reset registers.
Modified: cpu/arm/mmp2/apbc.fth cpu/arm/mmp2/pmua.fth
Modified: cpu/arm/mmp2/apbc.fth ============================================================================== --- cpu/arm/mmp2/apbc.fth Thu Aug 9 14:27:13 2012 (r3143) +++ cpu/arm/mmp2/apbc.fth Thu Aug 9 14:28:19 2012 (r3144) @@ -44,6 +44,7 @@ " UART4" +string \ 32 " RIPC" +string \ 33 " THSENS1" +string \ 34 +" CORESIGHT" +string \ 35 " clock-output-names" property
: +int encode-int encode+ ; @@ -85,6 +86,7 @@ h# 88 +int h# 77 +int h# 17 +int d# 26,000,000 +int \ 32 UART4 h# 8c +int h# 77 +int h# 7 +int d# 26,000,000 +int \ 33 RIPC h# 90 +int h# 77 +int h# 7 +int d# 26,000,000 +int \ 34 THSENS1 +h# 94 +int h# 7 +int h# 7 +int d# 26,000,000 +int \ 35 CORESIGHT " clock-enable-registers" property
end-package
Modified: cpu/arm/mmp2/pmua.fth ============================================================================== --- cpu/arm/mmp2/pmua.fth Thu Aug 9 14:27:13 2012 (r3143) +++ cpu/arm/mmp2/pmua.fth Thu Aug 9 14:28:19 2012 (r3144) @@ -38,6 +38,13 @@ " ISP" +string \ 22 " EPD" +string \ 23 " APB2" +string \ 24 +" SPMI" +string \ 25 +" EPD" +string \ 26 +" USB3SS" +string \ 27 +" SDH4" +string \ 28 +" DSA" +string \ 29 +" TPIU" +string \ 30 +" ISP" +string \ 31 " clock-output-names" property
: +int encode-int encode+ ; @@ -69,6 +76,15 @@ h# 120 +int h# 3f +int h# 3f +int d# 0 +int \ 22 ISP h# 124 +int h# 1b +int h# 1b +int d# 0 +int \ 23 EPD h# 134 +int h# 12 +int h# 12 +int d# 0 +int \ 24 APB2 +[ifdef] mmp3 +h# 140 +int h# 1b +int h# 1b +int d# 0 +int \ 25 SPMI - XXX may need to set clock divisor bits +h# 144 +int h# 21b +int h# 21b +int d# 0 +int \ 26 EPD +h# 148 +int h# 9 +int h# 9 +int d# 0 +int \ 27 USB3SS +h# 15c +int h# 1b +int h# 1b +int d# 0 +int \ 28 SDH4 +h# 164 +int h# f +int h# f +int d# 0 +int \ 29 DSA xx +h# 18c +int h# 12 +int h# 12 +int d# 0 +int \ 30 TPIU +h# 224 +int h# 1b +int h# 1b +int d# 0 +int \ 31 ISP Need to do the redundancy dance +[then] " clock-enable-registers" property
end-package
