Author: wmb Date: Sun Oct 16 02:32:50 2011 New Revision: 2619 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2619
Log: Checked in ARM 16bpp to 24bpp conversion function in case we need it later.
Added: cpu/arm/rgb566cvt.fth
Added: cpu/arm/rgb566cvt.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/rgb566cvt.fth Sun Oct 16 02:32:50 2011 (r2619) @@ -0,0 +1,50 @@ +purpose: Copy from 16bpp to 24bpp frame buffer format + +code copy16>24-line ( src-adr dst-adr #pixels -- ) + mov r2,tos \ #pixels in r2 + ldmia sp!,{r0,r1,tos} \ r0: src, r1: dst, r2: #pixels + begin + ldrh r3,[r0] + inc r3,2 + + mov r4,r3,lsr #8 + and r4,r4,#0xf8 + strb r4,[r1],#1 + + mov r4,r3,lsr #3 + and r4,r4,#0xfc + strb r4,[r1],#1 + + mov r4,r3,lsl #3 + and r4,r4,#0xf8 + strb r4,[r1],#1 + + decs r2,1 + 0= until +c; + +0 value rect-w +0 value rect-h + +0 value dst-base +0 value dst-pitch +0 value dst-x +0 value dst-y + +: dst-base ( -- adr ) dst-y dst-pitch * dst-x + ; + +0 value src-base +0 value src-pitch +0 value src-x +0 value src-y + +: src-base ( -- adr ) dst-y dst-pitch * dst-x + ; + +: copy16>24 ( src-base src-pitch src-x,y dst-x,y w,h -- ) + src-base dst-base ( src-adr dst-adr ) + rect-h 0 ?do ( src-adr dst-adr ) + 2dup rect-w copy16>24-line ( scr-adr dst-adr ) + swap src-pitch + swap dst-pitch + ( scr-adr' dst-adr' ) + loop ( src-adr dst-adr ) + 2drop ( ) +;
