Author: rsmith Date: 2009-07-03 07:58:09 +0200 (Fri, 03 Jul 2009) New Revision: 1237
Modified: cpu/x86/pc/olpc/rtcwake.fth cpu/x86/pc/olpc/via/devices.fth cpu/x86/pc/olpc/via/versions.fth Log: - Version bump to q3a05 - Include EC code 1.9.5 - Add EC wakeup testing words - Re-enable battery.fth so OFW can talk with the EC about the battery
Modified: cpu/x86/pc/olpc/rtcwake.fth =================================================================== --- cpu/x86/pc/olpc/rtcwake.fth 2009-07-03 04:25:06 UTC (rev 1236) +++ cpu/x86/pc/olpc/rtcwake.fth 2009-07-03 05:58:09 UTC (rev 1237) @@ -69,6 +69,18 @@ key drop ;
+: autowack-test ( ms -- ) + autowack-delay + autowack-on + 0 begin + s + dup space .d (cr 1+ key? + until + ." Keypress Exit key= " + key . drop + autowack-off +; + \ for testing wakeups from the EC : wackup-test-ec ( ms -- ) d# 3000 autowack-delay \ At small ms delays the host can miss the SCI so this @@ -80,7 +92,8 @@ swap dup ( ms count count ) space .d (cr 1+ key? ( ms count+1 ) until - key drop 2drop + ." Keypress Exit key= " + key . 2drop autowack-off ;
Modified: cpu/x86/pc/olpc/via/devices.fth =================================================================== --- cpu/x86/pc/olpc/via/devices.fth 2009-07-03 04:25:06 UTC (rev 1236) +++ cpu/x86/pc/olpc/via/devices.fth 2009-07-03 05:58:09 UTC (rev 1237) @@ -319,7 +319,7 @@ .( XXX Reinstate kbdtype.fth) cr \ fload ${BP}/cpu/x86/pc/olpc/kbdtype.fth \ Export keyboard type
-[ifdef] use-ec-Later +[ifdef] use-ec fload ${BP}/dev/olpc/kb3700/battery.fth \ Battery status reports [else] : ?enough-power ;
Modified: cpu/x86/pc/olpc/via/versions.fth =================================================================== --- cpu/x86/pc/olpc/via/versions.fth 2009-07-03 04:25:06 UTC (rev 1236) +++ cpu/x86/pc/olpc/via/versions.fth 2009-07-03 05:58:09 UTC (rev 1237) @@ -2,16 +2,15 @@
\ The overall firmware revision macro: FW_MAJOR A -macro: FW_MINOR 04b +macro: FW_MINOR 05
\ The EC microcode -macro: EC_VERSION 1_9_4 +macro: EC_VERSION 1_9_5
\ Alternate command for getting EC microcode, for testing new versions. \ Temporarily uncomment the line and modify the path as necessary -\ macro: GET_EC cp pq3a00.img ec.img -\ macro: GET_EC wget -q http://dev.laptop.org/pub/ec/ec_via_test.img -O ec.img -\ macro: GET_EC wget -q http://dev.laptop.org/pub/ec/cl1b-1_9_0rc2.img -O ec.img +\ macro: GET_EC cp ~rsmith/olpc/ec/ec-code15/image/ecimage.bin ec.img +\ macro: GET_EC wget -q http://dev.laptop.org/pub/ec/ec_test.img -O ec.img
macro: KEYS mpkeys \ macro: KEYS testkeys
