Author: wmb Date: Fri Jun 29 22:27:32 2012 New Revision: 3019 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3019
Log: Intermediate step in preparation for renaming resetvec.bth to resetvec.fth
Modified: cpu/arm/olpc/resetvec.bth
Modified: cpu/arm/olpc/resetvec.bth ============================================================================== --- cpu/arm/olpc/resetvec.bth Thu Jun 28 10:51:30 2012 (r3018) +++ cpu/arm/olpc/resetvec.bth Fri Jun 29 22:27:32 2012 (r3019) @@ -1,16 +1,11 @@ \ See license at end of file purpose: Low-level startup code
-command: &builder &this -build-now - \ create debug-reset
\needs start-assembling fload ${BP}/cpu/arm/asmtools.fth \needs write-dropin fload ${BP}/forth/lib/mkdropin.fth
-fload ${BP}/cpu/arm/olpc/1.75/config.fth - hex
also forth definitions @@ -38,9 +33,7 @@ label my-entry \ **** This is the primary entry point; it will contain a branch instruction \ that skips a few subroutines and lands at the startup sequence. That -\ branch instruction is patched in below. The entry point for this module -\ is in turn reached from a branch instruction at the beginning of the ROM, -\ which is created by the file arch/dna/resetvec.bth +\ branch instruction is patched in below. 0 , \ To be patched later end-code
