Author: wmb Date: 2009-10-23 01:10:09 +0200 (Fri, 23 Oct 2009) New Revision: 1425
Added: cpu/x86/pc/olpc/via/startgfxrestore.fth Modified: cpu/x86/pc/olpc/via/romreset.bth cpu/x86/pc/olpc/via/startcfgio.fth cpu/x86/pc/olpc/via/startmacros.fth Log: Via - restore display state in resume path.
Modified: cpu/x86/pc/olpc/via/romreset.bth =================================================================== --- cpu/x86/pc/olpc/via/romreset.bth 2009-10-19 18:27:59 UTC (rev 1424) +++ cpu/x86/pc/olpc/via/romreset.bth 2009-10-22 23:10:09 UTC (rev 1425) @@ -220,6 +220,7 @@ \ Setup a small stack for subroutine calls h# 10.0000 # esp mov
+ long-offsets on acpi-io-base 4 + port-rw \ Get APCI Status register ax bx mov d# 10 # ax shr 7 # ax and 1 # ax cmp = if \ Wakeup from S3 @@ -227,6 +228,8 @@ bx ax mov h# 1c00 invert # ax and acpi-io-base 4 + # dx mov op: ax dx out char r report
+ fload ${BP}/cpu/x86/pc/olpc/via/startgfxrestore.fth \ Display restoration + cli
facs-adr h# 18 + #) ax mov ax ax or 0<> if \ X_Firmware_Waking_Vector @@ -241,6 +244,7 @@
char x report then \ Not a wakeup from S3 + long-offsets off
char o report h# 1e port80
Modified: cpu/x86/pc/olpc/via/startcfgio.fth =================================================================== --- cpu/x86/pc/olpc/via/startcfgio.fth 2009-10-19 18:27:59 UTC (rev 1424) +++ cpu/x86/pc/olpc/via/startcfgio.fth 2009-10-22 23:10:09 UTC (rev 1425) @@ -78,4 +78,21 @@ esi push ret end-code - + +label indexed-writes \ return address points to the table, index port in dx + esi pop + cld + begin + al lods \ al: register index + al al or 0<> while + al bl mov \ bl: register index + + al dx out + al lods \ Get final value (== OR mask) + dx inc + al dx out + dx dec + repeat + esi push + ret +end-code
Added: cpu/x86/pc/olpc/via/startgfxrestore.fth =================================================================== --- cpu/x86/pc/olpc/via/startgfxrestore.fth (rev 0) +++ cpu/x86/pc/olpc/via/startgfxrestore.fth 2009-10-22 23:10:09 UTC (rev 1425) @@ -0,0 +1,119 @@ +\ Restore PCI config registers + +d000.0000 810 config-wl \ Frame buffer base address +f000.0000 814 config-wl \ Graphics engine base address + 0007 804 config-ww \ Enables + 20 80d config-wb \ Latency timer + +\ Clock DCON SMBUS in case it is stuck in the middle of an address +\ recognition sequence. + +long-offsets @ long-offsets off +31 26 seq-set +4 wait-us +d# 32 # cx mov +begin + 20 26 seq-clr + 4 wait-us + 20 26 seq-set + 4 wait-us +loopa +long-offsets ! + +\ DCON GPIO pin muxing +d# 17 0 devfunc + e3 04 04 mreg \ Use multifunction pin as GPIO8 + e4 48 48 mreg \ Use multifunction pins as GPO10 and GPI10/11 +end-table + +\ olpc-lcd-mode + +c0 1b seq-set \ Secondary engine clock (LCK) can be gated on or off + +80 17 crt-clr \ Assert reset while programming geometry + +crtc-table + 30 36 ireg \ Turn off primary DAC to save power + + d7 50 ireg \ Htotal low + af 51 ireg \ Hdisplay low + af 52 ireg \ Hblank low + d7 53 ireg \ Hblankend + 24 54 ireg \ Hblank, Hblankend overflow + 44 55 ireg \ Htotal and hdisplay overflow + \ b7 56 ireg \ Hsync low + b8 56 ireg \ Hsync low + c0 57 ireg \ Hsyncend low + 8f 58 ireg \ Vtotal low + 83 59 ireg \ Vdisplay low + 83 5a ireg \ Vblank low + 8f 5b ireg \ Vblankend low + 9b 5c ireg \ Hsync,Hsyncend,Vblank,Vblankend overflow + 1b 5d ireg \ Hblankend, Hsync, Vtotal, Vdisplay overflow + 89 5e ireg \ Vsync low + 6e 5f ireg \ Vsyncend all and Vsync overflow + + 00 62 ireg \ Starting address + 00 63 ireg \ Starting address + 00 64 ireg \ Starting address + + 96 65 ireg \ Fetch count (67 overflow already set above) + 2c 66 ireg \ Offset (frame buffer pitch) low (67 overflow already set above) + 51 67 ireg \ Color depth - 16bpp ([7:6] = 10) - no interlace ([5] = 0), various overflow bits + f0 68 ireg \ Display queue depth + c8 6a ireg \ Enable secondary display + 00 6b ireg \ Disable simultaneous display, IGA2 on, IGA2 screen enable not slaved to IGA1 + + 00 6c ireg \ VCK source from PLL output clock, LCKCK PLL source from X1 pin + + 7f 71 ireg \ Offset overflow + 00 79 ireg \ LCD scaling off + + 60 88 ireg \ LVDS sequential + 01 8a ireg \ LCD adjust LP + 08 94 ireg \ Expire number + 11 95 ireg \ extension bits + 10 97 ireg \ LVDS channel 2 - secondary display + 1b 9b ireg \ DVP mode - alpha:80, VSYNC:40, HSYNC:20, secondary:10, clk polarity:8, clk adjust:7 + 00 a3 ireg \ IGA2 frame buffer is system local memory, address bits [28:26] are 0 + 8b a7 ireg \ expected vertical display low + 01 a8 ireg \ expected vertical display high + + 80 f3 ireg \ 18-bit TTL LCD + 0a f9 ireg \ V1 power mode exit delay + 0d fb ireg \ IGA2 Interlace VSYNC timing +end-table + +seq-table + 9d 4a ireg \ 2nd PLL value 0 + 0c 4b ireg \ 2nd PLL value 1 + 05 4c ireg \ 2nd PLL value 2 + 04 40 ireg \ Pulse LCDCK PLL reset + 00 40 ireg \ Release LCDCK PLL reset +end-table + +3cc port-rb 0c bitset 3c2 # dx mov al dx out \ use external clock (MISC register reads at 3cc, writes at 3c2) + +80 17 crt-set \ Release reset + +60 78 seq-set \ Inverse HSYNC and VSYNC on IGA2 for LVDS +30 1e seq-set \ Power up DVP1 pads +0c 2a seq-set \ Power up LVDS pads +40 16 seq-set \ Undocumented bits, something to do with simultaneous CRT and LCD operation +30 1b seq-set \ Turn off primary engine clock to save power + +d# 32000 wait-us +\ Wait for DCON_BLNK to be low +d# 100 # cx mov +begin + acpi-io-base 4a + port-rb + 4 # al and +0<> while + d# 1000 wait-us + cx dec +0= until then \ "then" resolves "while" + +\ This is a cheesy way to set the DCON LOAD bit -- +ff acpi-io-base 4d + port-wb \ B1 and B2 - DCON LOAD is the 0x04 bit (bit number 2) of PMIO+4d +ff acpi-io-base 4f + port-wb \ A1 and A2 - DCON LOAD is the 0x10 bit (bit number 4) of PMIO+4f +d# 19000 wait-us
Modified: cpu/x86/pc/olpc/via/startmacros.fth =================================================================== --- cpu/x86/pc/olpc/via/startmacros.fth 2009-10-19 18:27:59 UTC (rev 1424) +++ cpu/x86/pc/olpc/via/startmacros.fth 2009-10-22 23:10:09 UTC (rev 1425) @@ -19,3 +19,56 @@ " h# ff port80 d# 200000 wait-us" eval " config-rb al 80 # out d# 1000000 wait-us" eval ; + +: index-table ( index-register -- ) + [ also assembler ] + # dx mov " indexed-writes" evaluate #) call + [ previous ] +; +: crtc-table ( -- ) h# 3d4 index-table ; +: seq-table ( -- ) h# 3c4 index-table ; + +: seq-setup ( index -- ) + [ also assembler ] + # al mov + h# 3c4 # dx mov + al dx out + dx inc + [ previous ] +; + +: seq-rb ( index -- ) seq-setup " dx al in" evaluate ; +: seq-wb ( data index -- ) seq-setup " # al mov al dx out" evaluate ; +: seq-set ( bitmask index -- ) + seq-rb ( index bitmask ) + \ Depends on index register already being set and dx already containing 3c5 + " # al or al dx out" evaluate +; +: seq-clr ( bitmask index -- ) + seq-rb ( index bitmask ) + \ Depends on index register already being set and dx already containing 3c5 + invert " # al and al dx out" evaluate +; + +: crt-setup ( index -- ) + [ also assembler ] + # al mov + h# 3d4 # dx mov + al dx out + dx inc + [ previous ] +; +: crt-rb ( index -- ) crt-setup " dx al in" evaluate ; +: crt-wb ( data index -- ) crt-setup " al dx out" evaluate ; +: crt-set ( bitmask index -- ) + crt-rb ( bitmask ) + \ Depends on index register already being set and dx already containing 3c5 + " # al or al dx out" evaluate +; +: crt-clr ( bitmask index -- ) + crt-rb ( bitmask ) + \ Depends on index register already being set and dx already containing 3c5 + invert " # al and al dx out" evaluate +; + +: ireg ( value reg# -- ) c, c, ;
