Author: wmb Date: 2009-12-16 01:42:29 +0100 (Wed, 16 Dec 2009) New Revision: 1618
Modified: cpu/x86/pc/olpc/via/fsupdate.fth dev/mmc/sdhci/sdhci.fth dev/mmc/sdhci/sdmmc.fth Log: Fsupdate - check for output device too small for image and for zblocks line mismatch.
Modified: cpu/x86/pc/olpc/via/fsupdate.fth =================================================================== --- cpu/x86/pc/olpc/via/fsupdate.fth 2009-12-15 23:32:49 UTC (rev 1617) +++ cpu/x86/pc/olpc/via/fsupdate.fth 2009-12-16 00:42:29 UTC (rev 1618) @@ -51,13 +51,26 @@ file ! ( ) ;
+: ?compare-spec-line ( -- ) + secure-fsupdate? if + data-buffer /spec-maxline filefd read-line ( len end? error? ) + " Spec line read error" ?nand-abort ( len end? ) + 0= " Spec line too long" ?nand-abort ( len ) + data-buffer swap ( adr len ) + source $= 0= " Spec line mismatch" ?nand-abort ( ) + then +; + vocabulary nand-commands also nand-commands definitions
: zblocks: ( "eblock-size" "#eblocks" ... -- ) + ?compare-spec-line get-hex# to /nand-block get-hex# to #image-eblocks open-nand + " size" $call-nand #image-eblocks /nand-block um* d< + " Image size is larger than output device" ?nand-abort #image-eblocks show-init get-inflater \ Separate the two buffers by enough space for both the compressed @@ -71,8 +84,9 @@
: zblocks-end: ( -- ) \ Asynchronous writes - " write-blocks-finish" $call-nand drop - #image-eblocks erase-gap + " write-blocks-end" $call-nand ( error? ) + " Write error" ?nand-abort +\ #image-eblocks erase-gap ;
: data: ( "filename" -- ) @@ -83,11 +97,6 @@ true " " ?nand-abort then to filefd linefeed filefd force-line-delimiter - \ Eat the initial "zblocks:" line - load-base /spec-maxline filefd read-line ( len not-eof? error? ) - " Read error on .zd file" ?nand-abort ( len not-eof? ) - 0= " Premature EOF on .zd file" ?nand-abort ( len ) - drop ( ) true to secure-fsupdate? ;
@@ -97,17 +106,9 @@ ;
: get-zdata ( comprlen -- ) - secure-fsupdate? if - data-buffer /spec-maxline filefd read-line ( len end? error? ) - " Spec line read error" ?nand-abort ( len end? ) - 0= " Spec line too long" ?nand-abort ( len ) - data-buffer swap ( adr len ) - source $= 0= " Spec line mismatch" ?nand-abort ( ) + ?compare-spec-line
- filefd ( ih ) - else ( ) - source-id ( ih ) - then ( ih ) + secure-fsupdate? if filefd else source-id then ( ih )
>r data-buffer /nand-block + over r@ fgets ( comprlen #read r: ih ) <> " Short read of zdata file" ?nand-abort ( r: ih ) @@ -178,7 +179,8 @@
( eblock# ) \ Asynchronous writes - data-buffer over nand-pages/block * nand-pages/block " write-blocks-start" $call-nand ( eblock# ) + data-buffer over nand-pages/block * nand-pages/block " write-blocks-start" $call-nand ( eblock# error? ) + " Write error" ?nand-abort ( eblock# ) \ data-buffer over nand-pages/block * nand-pages/block " write-blocks" $call-nand ( eblock# #written ) \ nand-pages/block <> " Write error" ?nand-abort ( eblock# ) swap-buffers ( eblock# )
Modified: dev/mmc/sdhci/sdhci.fth =================================================================== --- dev/mmc/sdhci/sdhci.fth 2009-12-15 23:32:49 UTC (rev 1617) +++ dev/mmc/sdhci/sdhci.fth 2009-12-16 00:42:29 UTC (rev 1618) @@ -691,9 +691,29 @@
0 instance value writing?
+: .card-error ( value -- ) + dup h# 8000.0000 and if ." Address out of range (past end?)" cr then + dup h# 4000.0000 and if ." Misaligned address" cr then + dup h# 2000.0000 and if ." Block length error" cr then + dup h# 1000.0000 and if ." Erase sequence error" cr then + dup h# 0800.0000 and if ." Invalid erase block error" cr then + dup h# 0400.0000 and if ." Write protect violation" cr then +\ dup h# 0200.0000 and if ." Card is locked" cr then \ Status, not error + dup h# 0100.0000 and if ." Lock/Unlock failed" cr then + dup h# 0080.0000 and if ." Command CRC error" cr then + dup h# 0040.0000 and if ." Illegal command " cr then + dup h# 0020.0000 and if ." Card ECC failed" cr then + dup h# 0010.0000 and if ." Card controller error" cr then + dup h# 0008.0000 and if ." General error" cr then + dup h# 0001.0000 and if ." CIS/CSD overwrite" cr then + dup h# 0000.8000 and if ." Write-protected blocks skipped" cr then + dup h# 0000.0008 and if ." Authentication sequence error" cr then + drop +; + \ This is the correct way to wait for programming complete. -: wait-write-done ( -- ) - writing? 0= if exit then ( limit ) +: wait-write-done ( -- error? ) + writing? 0= if false exit then ( limit )
get-msecs d# 1000 + ( limit ) begin get-status dup 9 rshift h# f and 7 = while ( limit status ) @@ -704,11 +724,13 @@ then repeat ( limit status ) nip ( status ) - dup h# fff9.8008 and if ( status ) - cr ." SD Error - status = " . cr - noop + dup h# fdf9.8008 and if ( status ) + cr ." SD Error - status = " dup . cr + .card-error + true else drop + false then
false to writing? @@ -806,7 +828,7 @@
: detach-card ( -- ) wait-dma-done - intstat-on wait-write-done intstat-off + intstat-on wait-write-done drop intstat-off card-clock-off card-power-off \ unmap-regs @@ -843,28 +865,34 @@ : detach-sdio-card ( -- ) ;
+: r/w-blocks-end ( -- error? ) + wait-dma-done + intstat-on wait-write-done intstat-off +; + : r/w-blocks-finish ( -- actual ) wait-dma-done dma-len /block / ;
-: r/w-blocks-start ( addr block# #blocks in? -- ) +: r/w-blocks-start ( addr block# #blocks in? -- error? ) wait-dma-done - over 0= if 2drop 2drop 0 exit then \ Prevents hangs + over 0= if 2drop 2drop false exit then \ Prevents hangs intstat-on >r ( addr block# #blocks r: in? ) rot dma-setup ( block# r: in? ) - wait-write-done + wait-write-done if true exit then address-shift lshift r> if read-multiple else write-multiple true to writing? then true to dma? + false ;
: r/w-blocks ( addr block# #blocks in? -- actual ) - r/w-blocks-start r/w-blocks-finish + r/w-blocks-start if -1 exit then r/w-blocks-finish ;
: r/w-ioblocks ( reg# function# inc? addr len blksz in? -- actual ) @@ -874,7 +902,7 @@ 2dup tuck 1- + swap / to io-#blocks ( reg# function# inc? addr len blksz r: in? ) 4 pick write-blksz ( reg# function# inc? addr len r: in? ) iodma-setup ( reg# function# inc? r: in? ) - wait-write-done + wait-write-done if -1 exit then r> if ( reg# function# inc? ) io-read-blocks else
Modified: dev/mmc/sdhci/sdmmc.fth =================================================================== --- dev/mmc/sdhci/sdmmc.fth 2009-12-15 23:32:49 UTC (rev 1617) +++ dev/mmc/sdhci/sdmmc.fth 2009-12-16 00:42:29 UTC (rev 1618) @@ -34,11 +34,11 @@ \ Asynchronous write. Completes on the next call to \ write-blocks-start, write-blocks-finish, or close. \ (Don't do other read/write operations in between.) -: write-blocks-start ( adr block# #blocks -- ) +: write-blocks-start ( adr block# #blocks -- error? ) false " r/w-blocks-start" $call-parent ; -: write-blocks-finish ( -- #written ) - false " r/w-blocks-finish" $call-parent +: write-blocks-end ( -- error? ) + false " r/w-blocks-end" $call-parent ;
: dma-alloc ( size -- vadr ) " dma-alloc" $call-parent ;
