Author: wmb Date: Tue May 31 21:33:27 2011 New Revision: 2235 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2235
Log: USB - moved some functions from an EHCI-specific file to a common file to fix compilation errors for other host controllers.
Modified: dev/usb2/hcd/device.fth dev/usb2/hcd/ehci/probe.fth dev/usb2/hcd/probehub.fth
Modified: dev/usb2/hcd/device.fth ============================================================================== --- dev/usb2/hcd/device.fth Tue May 31 01:23:49 2011 (r2234) +++ dev/usb2/hcd/device.fth Tue May 31 21:33:27 2011 (r2235) @@ -491,6 +491,17 @@ drop false ( false ) ;
+: probe-setup ( -- ) + \ Set active-package so device nodes can be added and removed + my-self ihandle>phandle push-package + + alloc-pkt-buf +; +: probe-teardown ( -- ) + free-pkt-buf + pop-package +; + headers
\ LICENSE_BEGIN
Modified: dev/usb2/hcd/ehci/probe.fth ============================================================================== --- dev/usb2/hcd/ehci/probe.fth Tue May 31 01:23:49 2011 (r2234) +++ dev/usb2/hcd/ehci/probe.fth Tue May 31 21:33:27 2011 (r2235) @@ -42,17 +42,6 @@ dup portsc@ swap portsc! ( ) \ Clear connection change bit ;
-: probe-setup ( -- ) - \ Set active-package so device nodes can be added and removed - my-self ihandle>phandle push-package - - alloc-pkt-buf -; -: probe-teardown ( -- ) - free-pkt-buf - pop-package -; - : #testable-ports ( -- n ) #ports ( #hardware-ports ) " usb-test-ports" get-inherited-property 0= if ( #hardware-ports adr len )
Modified: dev/usb2/hcd/probehub.fth ============================================================================== --- dev/usb2/hcd/probehub.fth Tue May 31 01:23:49 2011 (r2234) +++ dev/usb2/hcd/probehub.fth Tue May 31 21:33:27 2011 (r2235) @@ -193,7 +193,7 @@ " hub-port-mask" get-inherited-property if ( ) -1 ( mask ) else ( propval$ ) - get-encoded-int ( mask ) + decode-int nip nip ( mask ) then ( mask ) to hub-test-mask ( )
