Author: wmb Date: 2009-04-02 20:43:45 +0200 (Thu, 02 Apr 2009) New Revision: 1135
Modified: cpu/x86/pc/resetend.fth Log: Minor change to position of serial reports in resetend.h, affects only the unusual case where the FW dropin is not compressed.
Modified: cpu/x86/pc/resetend.fth =================================================================== --- cpu/x86/pc/resetend.fth 2009-04-02 18:27:04 UTC (rev 1134) +++ cpu/x86/pc/resetend.fth 2009-04-02 18:43:45 UTC (rev 1135) @@ -111,6 +111,8 @@ ax call \ Inflate the firmware else h# 26 # al mov al h# 80 # out + ascii h report + \ The firmware dropin isn't compressed, so we just copy it to RAM 4 [ax] cx mov \ Length of firmware (byte-swapped) cx bswap \ cx: Length of firmware @@ -119,7 +121,6 @@ fw-virt-base # di mov \ Firmware RAM address (destination) cld rep byte movs \ Copy the firmware
- ascii h report ascii m report then long-offsets off
