Author: quozl Date: Mon Oct 29 06:39:46 2012 New Revision: 3391 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3391
Log: OLPC - stack imbalance after (hub-selftest) fails causes test-all failure, regression introduced in r2412 by me
Modified: dev/usb2/hcd/probehub.fth
Modified: dev/usb2/hcd/probehub.fth ============================================================================== --- dev/usb2/hcd/probehub.fth Sat Oct 27 09:00:31 2012 (r3390) +++ dev/usb2/hcd/probehub.fth Mon Oct 29 06:39:46 2012 (r3391) @@ -230,7 +230,7 @@ base @ >r decimal ( list$' dev#$ ) $number if 0 then ( list$' port# ) r> base ! ( list$ port# ) - (hub-selftest) if drop true exit then ( list$ ) + (hub-selftest) if 2drop true exit then ( list$ ) repeat ( list$ ) 2drop ( ) then ( )
