Author: wmb Date: Tue Jul 3 07:27:26 2012 New Revision: 3031 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3031
Log: Checked in intel hex file support.
Added: forth/lib/intelhex.fth
Added: forth/lib/intelhex.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ forth/lib/intelhex.fth Tue Jul 3 07:27:26 2012 (r3031) @@ -0,0 +1,64 @@ +\ See license at end of file +purpose: Intel hex format decoder + +\ Defines: +\ parse-ihex-record ( adr len -- data-adr data-len offset type ) + +variable ihex-sum + +: ihex-char ( adr len -- adr' len' char ) + dup 0= abort" Unexpected end of ihex line" + over c@ >r 1 /string r> +; +: ihex-nibble ( adr len -- adr' len' nibble ) + ihex-char h# 10 digit 0= abort" Bad hex character in ihex data" +; +: ihex-byte ( adr len -- adr' len' byte ) + ihex-nibble >r ihex-nibble r> 4 lshift or + dup ihex-sum +! +; +: ihex-address ( adr len -- adr' len' word ) + ihex-byte >r ihex-byte r> bwjoin +; + +h# 20 buffer: ihex-data +: parse-ihex-record ( adr len -- data-adr data-len offset type ) + ihex-char [char] : <> abort" Bad start character in ihex file" + + ihex-sum off ( adr len ) + ihex-byte >r ( adr len r: datalen ) + ihex-address -rot ( offset adr len r: datalen ) + ihex-byte -rot ( offset type adr len r: datalen ) + r@ h# 20 > abort" Ihex record too long" + r@ 0 ?do ( offset type adr len r: datalen ) + ihex-byte ihex-data i + c! ( offset type adr len r: datalen ) + loop ( offset type adr len r: datalen ) + ihex-byte drop ( offset type adr len r: datalen ) + ihex-sum @ h# ff and abort" Bad ihex checksum" + 2drop ( offset type r: datalen ) + ihex-data r> 2swap ( data-adr data-len offset type ) +; + +\ LICENSE_BEGIN +\ Copyright (c) 2012 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
