Author: quozl Date: Mon Nov 21 05:09:15 2011 New Revision: 2695 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2695
Log: OLPC - instance buffer scan-ssid is d# 34 bytes long, so the maximum length check in set-ssid was invalid, (found during code review only)
Modified: dev/libertas.fth
Modified: dev/libertas.fth ============================================================================== --- dev/libertas.fth Mon Nov 21 01:23:36 2011 (r2694) +++ dev/libertas.fth Mon Nov 21 05:09:15 2011 (r2695) @@ -1040,7 +1040,7 @@ 2dup " olpc-mesh" $= if passive-scan then 2dup " olpc-NANDblaster" $= if passive-scan then
- h# 32 min scan-ssid pack drop + d# 32 min scan-ssid pack drop ;
: scan ( adr len -- actual )
