Author: quozl Date: Wed Aug 29 04:21:27 2012 New Revision: 3239 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3239
Log: OLPC XO-4 - bsl, hide destructive test, provide dot per line progress during programming
Modified: cpu/arm/olpc/bsl.fth
Modified: cpu/arm/olpc/bsl.fth ============================================================================== --- cpu/arm/olpc/bsl.fth Wed Aug 29 03:20:38 2012 (r3238) +++ cpu/arm/olpc/bsl.fth Wed Aug 29 04:21:27 2012 (r3239) @@ -4,7 +4,6 @@
\ TODO: \ friendlier programming interface ( "ok flash-bsl u:\file.hex") -\ progress indicator during programming \ print, perhaps in red, the msp430 password after programming, \ iff the password doesn't match all-ff or the known neonode password. \ save calibration data in mfg tag, in case it's lost. @@ -484,6 +483,7 @@ force-erase ( ) ." Programming" cr begin ( ) + [char] . emit bsl-line-buf d# 100 ifd @ read-line abort" Read line failed" while ( len ) bsl-line-buf swap ( adr len ) @@ -495,6 +495,7 @@ ifd @ fclose ( ) ;
+[ifdef] bsl-destructive-test \ This is a destructive test in that it erases whatever firmware happens \ to already be in the device.
@@ -543,6 +544,7 @@ ." Verifying ..." bsl-test-data h# 8000 bsl-verify cr ( okay? ) if ." Good" else ." FAILED!" then cr ; +[then]
\ LICENSE_BEGIN \ Copyright (c) 2012 FirmWorks
