Author: wmb Date: Sun Sep 2 01:42:57 2012 New Revision: 3269 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3269
Log: OLPC ARM - Map the memory controller in early startup code so it doesn't have to be done later.
Modified: cpu/arm/mmp2/initmmu.fth
Modified: cpu/arm/mmp2/initmmu.fth ============================================================================== --- cpu/arm/mmp2/initmmu.fth Sat Sep 1 20:48:30 2012 (r3268) +++ cpu/arm/mmp2/initmmu.fth Sun Sep 2 01:42:57 2012 (r3269) @@ -358,6 +358,11 @@ set r3,#0xc02 \ No caching or write buffering bl `map-sections-v=p`
+ set r1,`memctrl-pa #` \ Address of memory controller + set r2,`/io #` \ Size of I/O region + set r3,#0xc02 \ No caching or write buffering + bl `map-sections-v=p` + [ifdef] /audio-sram-map set r1,`audio-sram-pa #` \ Address of Audio SRAM set r2,`/audio-sram-map #` \ Map size of audio SRAM
