Author: wmb Date: Tue Aug 9 20:31:51 2011 New Revision: 2449 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2449
Log: Intel SPI driver - fixed write protect problem.
Modified: dev/intel/spi.fth
Modified: dev/intel/spi.fth ============================================================================== --- dev/intel/spi.fth Tue Aug 9 20:30:19 2011 (r2448) +++ dev/intel/spi.fth Tue Aug 9 20:31:51 2011 (r2449) @@ -1,5 +1,5 @@ \ See license at end of file -purpose: Driver for SPI FLASH chips connected via Intel NM10 SPI interface +purpose: Driver for SPI FLASH chips connected via Intel ICH7-style interface
h# fed1f020 value spi-base : spi-reg-b! ( b offset -- ) spi-base + c! ; @@ -24,32 +24,54 @@
\ Commands \ # t DCOA P Op -\ 0 0 4102 5 <no address> <1 data in> read-status +\ 0 0 4002 5 <no address> <1 data in> read-status \ 1 2 4n12 3 <ADDR> <N data in> read -\ 2 0 4322 9f <no address> <3 data in> jedec-id -\ 3 2 4232 90 <ADDR=0> <2 data in> 90-id -\ 4 2 4142 ab <ADDR=0> <1 data in> ab-id -\ 5 1 4156 6 1 <no address> <1 data out> write-status +\ 2 0 4222 9f <no address> <3 data in> jedec-id +\ 3 2 4132 90 <ADDR=0> <2 data in> 90-id +\ 4 2 4042 ab <ADDR=0> <1 data in> ab-id +\ 5 1 4056 6 1 <no address> <1 data out> write-status \ 6 3 4n66 6 2 <ADDR> <N data out> write -\ 7 3 0076 6 d8 <ADDR> <no data> erase-block +\ 7 2 0076 6 d8 <ADDR> <no data> erase-block
+\ 4 base ! 33122020 hex constant cycle-types 4 base ! 33122020 hex constant cycle-types -: intel-spi-start ( -- ) - h# 0406 spi-prefix! \ Prefix 0 is write-enable, 1 is write-disable +: ich7-uncache-flash ( -- ) + h# f8dc config-b@ h# c invert and 4 or h# f8dc config-b! +; +: ich7-cache-flash ( -- ) + h# f8dc config-b@ h# c invert and 8 or h# f8dc config-b! +; +: ich7-protect-flash ( -- ) + h# f8dc config-b@ 1 invert and h# f8dc config-b! +; +: ich7-unprotect-flash ( -- ) + h# f8dc config-b@ 1 or h# f8dc config-b! +; +: ich7-spi-start ( -- ) + \ Turn off SPI FLASH caching and prefetching, enable writing + ich7-unprotect-flash + h# 0606 spi-prefix! \ Write-enable for both prefixes h# d80201ab h# 5c spi-reg-l! \ opcodes 7-4 h# 909f0305 h# 58 spi-reg-l! \ opcodes 3-0 - cycle-types h# 56 spi-reg-w! + cycle-types spi-type! h# 0c spi-stat! ; -: spi-do-cmd ( code -- ) +: ich7-flash-close ( -- ) + ich7-protect-flash +; +: wait-ready ( -- ) begin spi-stat@ 1 and 0= until - spi-ctrl! - begin spi-stat@ 4 and until - 4 spi-stat! +; +: spi-do-cmd ( code -- ) + spi-ctrl! ( ) + begin spi-stat@ c and until ( ) + spi-stat@ 8 and abort" SPI access blocked" + h# c spi-stat! ; : spi-read-status ( -- b ) - h# 4002 spi-do-cmd - spi-data c@ + wait-ready ( ) + h# 4002 spi-do-cmd ( ) + spi-data c@ ( b ) ; : wait-write-done ( -- ) d# 100000 0 do @@ -58,30 +80,36 @@ loop ; : spi-read-n ( adr len offset -- ) + wait-ready ( adr len offset ) spi-addr! ( adr len ) dup 1- 8 lshift h# 4012 or spi-do-cmd ( adr len ) spi-data -rot move ( ) ; : jedec-id ( -- b3b2b1 ) - h# 4222 spi-do-cmd - spi-data w@ spi-data 2+ c@ wljoin + wait-ready ( ) + h# 4222 spi-do-cmd ( ) + spi-data w@ spi-data 2+ c@ wljoin ( b3b2b1 ) ; : 90-id ( -- b2b1 ) - 0 spi-addr! - h# 4132 spi-do-cmd - spi-data w@ + wait-ready ( ) + 0 spi-addr! ( ) + h# 4132 spi-do-cmd ( ) + spi-data w@ ( ) ; : ab-id ( -- b1 ) - 0 spi-addr! - h# 4042 spi-do-cmd - spi-data c@ + wait-ready ( ) + 0 spi-addr! ( ) + h# 4042 spi-do-cmd ( ) + spi-data c@ ( b ) ; : spi-write-status ( b -- ) + wait-ready ( b ) spi-data c! ( ) h# 4056 spi-do-cmd ( ) wait-write-done ( ) ; : spi-write-n ( adr len offset -- ) + wait-ready ( adr len offset ) spi-addr! ( adr len ) tuck ( len adr len ) spi-data swap move ( len ) @@ -89,6 +117,7 @@ wait-write-done ( ) ; : erase-spi-block ( offset -- ) + wait-ready ( offset ) spi-addr! ( ) h# 0076 spi-do-cmd ( ) wait-write-done ( ) @@ -220,18 +249,18 @@ \ Install the SPI FLASH versions as their implementations. : use-spi-flash ( -- ) ['] spi-flash-open to flash-open - ['] noop to flash-close + ['] ich7-flash-close to flash-close ['] spi-flash-write-enable to flash-write-enable - ['] noop to flash-write-disable + ['] flash-close to flash-write-disable ['] write-spi-flash to flash-write ['] verify-spi-flash to flash-verify ['] erase-spi-block to flash-erase-block - use-mem-flash-read \ Might be overridden + use-spi-flash-read h# 40.0000 to /flash /spi-eblock to /flash-block ; use-spi-flash -' intel-spi-start to spi-start +' ich7-spi-start to spi-start
\ LICENSE_BEGIN \ Copyright (c) 2011 FirmWorks
