Author: wmb Date: Sat Jan 8 11:15:54 2011 New Revision: 2105 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2105
Log: OLPC XO-1.75 A2 - Added support for switching between internal MicroSD and eMMC.
Added: cpu/arm/olpc/1.75/emmc.fth Modified: cpu/arm/olpc/1.75/devices.fth
Modified: cpu/arm/olpc/1.75/devices.fth ============================================================================== --- cpu/arm/olpc/1.75/devices.fth Sat Jan 8 11:12:51 2011 (r2104) +++ cpu/arm/olpc/1.75/devices.fth Sat Jan 8 11:15:54 2011 (r2105) @@ -223,6 +223,9 @@ ' 15x30pc to romfont
fload ${BP}/cpu/arm/olpc/1.75/sdhci.fth +[ifndef] cl2-a1 +fload ${BP}/cpu/arm/olpc/1.75/emmc.fth +[then]
devalias int /sd/disk@3 devalias ext /sd/disk@1 @@ -319,9 +322,11 @@ ec-api-ver@ " ec-version" integer-property [then]
+[ifndef] cl2-a2 \ XXX remove this ifndef when the new EC code is ready ['] ec-name$ catch 0= if " ec-name" string-property then ['] ec-date$ catch 0= if " ec-date" string-property then ['] ec-user$ catch 0= if " ec-user" string-property then +[then] dend
" /openprom" find-device
Added: cpu/arm/olpc/1.75/emmc.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/1.75/emmc.fth Sat Jan 8 11:15:54 2011 (r2105) @@ -0,0 +1,55 @@ +\ XXX do we need to set the internal SD for fast drive in boardgpio.fth ? +: select-internal-sd ( -- ) + ." Using internal SD" cr + h# d8c3 d# 113 af! \ SD_CMD + h# d8c3 d# 126 af! \ SD_DATA2 + h# d8c3 d# 127 af! \ SD_DATA0 + h# d8c3 d# 130 af! \ SD_DATA3 + h# d8c3 d# 135 af! \ SD_DATA1 + h# d8c3 d# 138 af! \ SD_CLK + h# c1 d# 111 af! \ eMMC_D0 as GPIO + h# c1 d# 112 af! \ eMMC_CMD as GPIO + h# c1 d# 151 af! \ eMMC_CLK as GPIO + h# c1 d# 162 af! \ eMMC_D6 as GPIO + h# c1 d# 163 af! \ eMMC_D4 as GPIO + h# c1 d# 164 af! \ eMMC_D2 as GPIO + h# c1 d# 165 af! \ eMMC_D7 as GPIO + h# c1 d# 166 af! \ eMMC_D5 as GPIO + h# c1 d# 167 af! \ eMMC_D3 as GPIO + h# c1 d# 168 af! \ eMMC_D1 as GPIO +; +: select-emmc ( -- ) + ." Using eMMC" cr + h# c1 d# 113 af! \ SD_CMD as GPIO + h# c1 d# 126 af! \ SD_DATA2 as GPIO + h# c0 d# 127 af! \ SD_DATA0 as GPIO + h# c0 d# 130 af! \ SD_DATA3 as GPIO + h# c0 d# 135 af! \ SD_DATA1 as GPIO + h# c0 d# 138 af! \ SD_CLK as GPIO + + \ XXX perhaps 18c2 for fast? + h# c2 d# 111 af! \ eMMC_D0 + h# c2 d# 112 af! \ eMMC_CMD + h# c2 d# 151 af! \ eMMC_CLK + h# c2 d# 162 af! \ eMMC_D6 + h# c2 d# 163 af! \ eMMC_D4 + h# c2 d# 164 af! \ eMMC_D2 + h# c2 d# 165 af! \ eMMC_D7 + h# c2 d# 166 af! \ eMMC_D5 + h# c2 d# 167 af! \ eMMC_D3 + h# c2 d# 168 af! \ eMMC_D1 + + d# 149 gpio-set \ Release eMMC_RST# + + d# 34 gpio-set \ This is for the case where the eMMC power is rewired to the WLAN +; +\ Says COMM - is RST# +\ Says RESET - is CMD + +stand-init: + d# 56 gpio-pin@ if + select-emmc + else + select-internal-sd + then +;
