Author: wmb Date: Wed Sep 26 11:15:13 2012 New Revision: 3329 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3329
Log: OFW core - extend Forth decompiler and debugger to handle instance defer words.
Modified: forth/lib/debug.fth forth/lib/decomp.fth ofw/core/ofwcore.fth
Modified: forth/lib/debug.fth ============================================================================== --- forth/lib/debug.fth Wed Sep 26 06:56:26 2012 (r3328) +++ forth/lib/debug.fth Wed Sep 26 11:15:13 2012 (r3329) @@ -60,8 +60,15 @@ \ Enter and leave the debugger forth definitions : defer? ( acf -- flag ) word-type ['] key word-type = ; -: (debug ( acf -- ) + +defer resolve-defers +: (resolve-defers) ( xt -- xt' ) begin dup defer? while behavior repeat +; +' (resolve-defers) to resolve-defers + +: (debug ( acf -- ) + resolve-defers
dup colon-cf? 0= abort" Not a colon definition" >body dup 'unnest (debug)
Modified: forth/lib/decomp.fth ============================================================================== --- forth/lib/decomp.fth Wed Sep 26 06:56:26 2012 (r3328) +++ forth/lib/decomp.fth Wed Sep 26 11:15:13 2012 (r3329) @@ -588,23 +588,37 @@ : cf, \ name ( -- ) \ Compile name's code field ' token, ; -d# 11 tassociative: definition-class +d# 12 constant #definition-classes +#definition-classes tassociative: definition-class ( 0 ) cf, : ( 1 ) cf, constant ( 2 ) cf, variable ( 3 ) cf, user ( 4 ) cf, defer ( 5 ) cf, create ( 6 ) cf, vocabulary ( 7 ) cf, alias ( 8 ) cf, value ( 9 ) cf, 2constant - ( 10) cf, code + ( 10) cf, code ( 11 ) cf, dummy
-d# 12 case: .definition-class +#definition-classes 1+ case: .definition-class ( 0 ) .: ( 1 ) .constant ( 2 ) .variable ( 3 ) .user ( 4 ) .defer ( 5 ) .create ( 6 ) .vocabulary ( 7 ) .alias ( 8 ) .value ( 9 ) .2constant - ( 10) .code ( 11) .other + ( 10) .code ( 11) dummy + ( 12) .other ;
+headers +also forth definitions +: install-decomp-definer ( definer-acf display-acf -- ) + ['] dummy ['] .definition-class (patch + ['] dummy ['] definition-class >body na1+ + dup [ #definition-classes ] literal ta+ tsearch + drop token! +; +previous definitions +headerless + + : does/;code-xt? ( xt -- flag ) dup ['] (does>) = swap ['] (;code) = or ;
Modified: ofw/core/ofwcore.fth ============================================================================== --- ofw/core/ofwcore.fth Wed Sep 26 06:56:26 2012 (r3328) +++ ofw/core/ofwcore.fth Wed Sep 26 11:15:13 2012 (r3329) @@ -904,17 +904,44 @@ action: >instance-data token@ ;
headerless +: instance-defer ( -- ) + create-cf ['] crash /token ( value data-size ) + use-actions value#, +; : (defer) ( -- ) instance? if - create-cf ['] crash /token ( value data-size ) - use-actions value#, + instance-defer else - defer-cf ['] crash /token ( value data-size ) - user#, + defer-cf ['] crash /token ( value data-size ) + user#, then ( value adr ) token! ; patch (defer) noop defer
+\ Extend debugger to handle instance defers +: (resolve-instance-defers) ( xt -- xt' ) + begin + dup defer? if ( xt ) + behavior ( xt' ) + else ( xt ) + dup definer ['] instance-defer = if ( xt ) + 2 perform-action ( xt' ) + else ( xt ) + exit + then + then + again +; +' (resolve-instance-defers) to resolve-defers + +\ Extend decompiler to handle instance defers +: .instance-defer ( xt definer -- ) + .definer ." is " cr ( xt ) + 2 perform-action ( xt' ) + (see) +; +' instance-defer ' .instance-defer install-decomp-definer + headers \ Instance values that are automatically created for every package instance.
