Author: wmb Date: 2009-04-29 10:13:15 +0200 (Wed, 29 Apr 2009) New Revision: 1160
Added: cpu/x86/pc/olpc/via/demodram.fth Modified: cpu/x86/pc/olpc/via/romreset.bth Log: Via demo version - split the DRAM settings into a separate file.
Added: cpu/x86/pc/olpc/via/demodram.fth =================================================================== --- cpu/x86/pc/olpc/via/demodram.fth (rev 0) +++ cpu/x86/pc/olpc/via/demodram.fth 2009-04-29 08:13:15 UTC (rev 1160) @@ -0,0 +1,331 @@ +\ Via timing settings for a specific 512MiB DIMM + +\ Detection.c +\ DRAMCmdRate + + 0 3 devfunc + 50 11 00 mreg \ Use stable 2T command rate + end-table + +\ h# 23 port80 d# 300000 wait-us + +\ FreqSetting.c : DRAMFreqSetting() + \ The following register is undocumented. coreboot has this comment: + \ Must use "CPU delay" to make sure VLINK is dis-connect + 0 7 devfunc 47 00 04 mreg end-table d# 20 wait-us + 0 3 devfunc 90 07 07 mreg end-table d# 20 wait-us \ First set DRAM Freq to invalid + 0 3 devfunc 90 07 04 mreg end-table d# 20 wait-us \ 266 MHz + 0 3 devfunc 6b d0 c0 mreg end-table d# 20 wait-us \ PLL Off + 0 3 devfunc 6b 00 10 mreg end-table d# 20 wait-us \ PLL On + 0 3 devfunc 6b c0 00 mreg end-table \ Adjustments off + 0 7 devfunc 47 04 00 mreg end-table \ disable V_LINK Auto-Disconnect + +\ h# 24 port80 d# 300000 wait-us + +\ TimingSetting.c + 0 3 devfunc + 61 ff 55 mreg \ Trfc, Trrd + 62 ff 8a mreg \ CL, Trp, Tras + 63 ff 49 mreg \ Twr, Twtr, Trtp + 64 ff 66 mreg \ Trp, Trcd + end-table + +\ DRDR_BL.c +\ DRAMDRDYsetting + 0 2 devfunc + 60 ff aa mreg \ DRDY Timing Control 1 for Read Line + 61 ff 0a mreg \ DRDY Timing Control 2 for Read Line + 62 ff 00 mreg \ Reserved, probably channel B + 63 ff aa mreg \ DRDY Timing Control 1 for Read QW + 64 ff 0a mreg \ DRDY Timing Control 2 for Read QW + 65 ff 00 mreg \ Reserved, probably channel B + 66 ff 00 mreg \ Burst DRDR Timing Control for Second cycle in burst + 67 ff 00 mreg \ Reserved, probably channel B + 54 0a 08 mreg \ Misc ctl 1 - special mode for DRAM cycles + 51 00 80 mreg \ Last step - enable DRDY timing - should the mask be f7 ? + end-table + +\ DRAMBurstLength + 0 3 devfunc + 6c 08 08 mreg \ Burst length 8 +\ DrivingSetting.c +\ DrivingODT + d0 ff 88 mreg \ Pull up/down Termination strength + d6 fc fc mreg \ DCLK/SCMD/CS drive strength + d3 fb 01 mreg \ Compensation control - enable DDR Compensation + 9e 30 10 mreg \ SRAM ODT Control 1 - 1T wait state turnaround + 9f 11 11 mreg \ SDRAM ODT Control 2 - Late extension values + d5 a0 00 mreg \ DQ/DQS Burst and ODT Range Select - disable bursts for channel A + d7 80 00 mreg \ SCMD/MA Burst - Disable SDMD/MAA burst + d5 0c 04 mreg \ Enable DRAM MD Pad ODT of Channel A High 32 bits + + 9c ff e1 mreg \ ODT Lookup table + d4 36 30 mreg \ ChannelA MD ODT dynamic-on + 9e 00 01 mreg \ Enable Channel A differential DQS Input + 9e 00 80 mreg \ Enable ODT controls + +\ DrivingDQS,DQ,CS,MA,DCLK + e0 ff ee mreg \ DQS A + e1 ff 00 mreg \ DQS B + e2 ff ac mreg \ DQ A + e3 ff 00 mreg \ DQ B + e4 ff 44 mreg \ CS A + e5 ff 00 mreg \ CS B + e6 ff ff mreg \ MCLK A + e7 ff 88 mreg \ MCKL B + e8 ff 86 mreg \ MA A + e9 ff 00 mreg \ MA B + +\ ClkCtrl.c (register tables in mainboard/via/6413e/DrivingClkPhaseData.c) +\ DutyCycleCtrl + ec ff 30 mreg \ DQS/DQ Output duty control + ee f0 00 mreg \ DCLK Output duty control + ef 30 00 mreg \ DQ CKG Input Delay - going with Phoenix value; coreboot uses 30 + +\ DRAMClkCtrl +\ WrtDataPhsCtrl + 74 07 00 mreg \ DQS Phase Offset + 75 07 00 mreg \ DQ Phase Offset + 76 ef 07 mreg \ Write data Phase control + 8c 03 03 mreg \ DQS Output Control + +\ ClkPhsCtrlFBMDDR2 + 91 07 00 mreg \ DCLK Phase + 92 07 03 mreg \ CS/CKE Phase + 93 07 04 mreg \ SCMD/MA Phase + +\ DQDQSOutputDlyCtrl + f0 ff 00 mreg \ Group A0/1 + f1 ff 00 mreg \ Group A2/3 + f2 ff 00 mreg \ Group A4/5 + f3 ff 00 mreg \ Group A6/7 + +\ DQSInputCaptureCtrl + 77 bf 8a mreg \ DQS Input Delay - Manual + 78 3f 03 mreg \ DQS Input Capture Range Control A + 7a 0f 00 mreg \ Reserved + 7b 7f 20 mreg \ Read Data Phase Control + +\ DCLKPhsCtrl + 99 1e 12 mreg \ MCLKOA[4,3,0] outputs + end-table + +\ DevInit.c +\ DRAMRegInitValue + + 0 3 devfunc + 50 ee ee mreg \ DDR default MA7 for DRAM init + 51 ee 60 mreg \ DDR default MA3 for CHB init + 52 ff 33 mreg \ DDR use BA0=M17, BA1=M18, + 53 ff 3F mreg \ DDR BA2=M19 + + 54 ff 00 mreg \ default PR0=VR0; PR1=VR1 + 55 ff 00 mreg \ default PR2=VR2; PR3=VR3 + 56 ff 00 mreg \ default PR4=VR4; PR5=VR5 + 57 ff 00 mreg \ default PR4=VR4; PR5=VR5 + + 60 ff 00 mreg \ disable fast turn-around + 65 ff D9 mreg \ AGP timer = D; Host timer = 8; + 66 ff 88 mreg \ DRAMC Queue Size = 4; park at the last bus owner,Priority promotion timer = 8 + 68 ff 0C mreg + 69 0F 04 mreg \ set RX69[3:0]=0000b + 6A ff 00 mreg \ refresh counter + 6E 07 80 mreg \ must set 6E[7],or else DDR2 probe test will fail + 85 ff 00 mreg + 40 ff 00 mreg + end-table + + 80 4a3 config-wb \ Enable toggle reduction on MA/SCMD per coreboot + +\ DRAMInitializeProc + + 0 3 devfunc + 6c 00 04 mreg \ Enable channel A only + + 54 ff 80 mreg \ Enable rank 0, disable rank 1 + 55 ff 00 mreg \ Disable ranks 2 and 3 + 40 ff 10 mreg \ Rank 0 top + 48 ff 00 mreg \ Rank 0 base + end-table + +\ h# 25 port80 d# 300000 wait-us + + DDRinit #) call + + h# 11 port80 + + 0 3 devfunc + 40 ff 00 mreg \ Rank 1 top back to 0 to work on other ranks + + 54 ff 09 mreg \ Enable rank 1 + 55 ff 00 mreg \ Disable ranks 2 and 3 + 41 ff 10 mreg \ Rank 1 top + 49 ff 00 mreg \ Rank 1 base + end-table + + DDRinit #) call + + 0 3 devfunc + 41 ff 00 mreg \ Rank 1 top back to 0 to work on other ranks + end-table + + h# 14 port80 + +0 [if] \ This is for a DIMM in the other socket + 0 3 devfunc + 54 ff 00 mreg \ Disable ranks 0,1 + 55 ff a0 mreg \ Enable Rank 2 + 42 ff 10 mreg \ Rank 2 top + 4a ff 00 mreg \ Rank 2 base + end-table + + DDRinit #) call + + 0 3 devfunc + 42 ff 00 mreg \ Rank 2 top back to 0 to work on other ranks + 54 ff 00 mreg \ Disable ranks 0,1 + 55 ff 0b mreg \ Enable Rank 3 + 43 ff 10 mreg \ Rank 3 top + 4b ff 00 mreg \ Rank 3 base + end-table + + DDRinit #) call + + 0 3 devfunc + 43 ff 00 mreg \ Rank 3 top back to 0 to work on other ranks + end-table +[then] + + 0 3 devfunc + 69 03 03 mreg \ Reinstate page optimizations (03) - FF #ranks + +\ RankMap.c +\ DRAMBankInterleave +\ (see 69 above) + 87 ff 00 mreg \ Channel B #banks or some such - FF BA +\ SizingMATypeM + + 50 ff 20 mreg \ MA Map type - ranks 0/1 type 1 - 2 bank bits, 10 column bits + 51 ff 60 mreg \ "Reserved" + 52 ff 33 mreg \ Bank interleave on A17, A18, and + 53 ff 3f mreg \ A19 (but BA2 off because 4 banks), Rank interleave on A20 and A21 + \ Different interleave bits might improve performance on some workloads + + 54 ff 89 mreg \ Rank map A 0/1 + 55 ff 00 mreg \ Rank map A 2/3 + 56 ff 00 mreg \ Rank map B ? + 57 ff 00 mreg \ Rank map B ? + + 40 ff 04 mreg \ Rank top 0 + 41 ff 08 mreg \ Rank top 1 + 42 ff 00 mreg \ Rank top 2 + 43 ff 00 mreg \ Rank top 3 + + 48 ff 00 mreg \ Rank base 0 + 49 ff 04 mreg \ Rank base 1 + 4a ff 00 mreg \ Rank base 2 + 4b ff 00 mreg \ Rank base 3 + end-table + + 20 8f60 config-wb \ DRAM Bank 7 ending address - controls DMA upstream + 0388 config-rb ax bx mov 0385 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to reg 85 + 0388 config-rb ax bx mov 8fe5 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to SB Low Top e5 + +0 [if] \ Very simple memtest +ax ax xor +h# 12345678 # bx mov +bx 0 [ax] mov +h# 5555aaaa # 4 [ax] mov +0 [ax] dx mov +dx bx cmp = if + ascii G report ascii 2 report h# 20 report +else + dx ax mov dot #) call + ascii B report ascii 2 report h# 20 report + hlt +then +[then] + +\ d# 17 7 devfunc +\ e6 ff 07 mreg \ Enable Top, High, and Compatible SMM +\ end-table + +\ DQSSearch.c +\ DRAMDQSOutputSearch + 0 3 devfunc + 70 ff 00 mreg \ Output delay + 71 ff 04 mreg + +\ DRAMDQSInputSearch + 77 ff 00 mreg \ Input delay auto + +\ FinalSetting.c +\ RefreshCounter + 6a ff 86 mreg \ Refresh interval - FF frequency + +\ DRAMRegFinalValue + 60 00 d0 mreg \ Fast turn-around + 66 30 80 mreg \ DRAMC queue = 4 (already set to 88 up above), park at last owner + 69 00 07 mreg \ Enable multiple page + 95 ff 0d mreg \ Self-refresh controls + 96 f0 a0 mreg \ Auto self-refresh stuff + fb ff 3e mreg \ Dynamic clocks + fd ff a9 mreg \ Dynamic clocks + fe ff 0f mreg \ Chips select power saving for self-refresh + ff ff 3d mreg \ DSQB input delay, SCMD enabled + 96 0f 03 mreg \ Enable self-refresh for ranks 0 and 1 + end-table + + 0 4 devfunc \ PM_table + a0 f0 f0 mreg \ Enable dynamic power management + a1 e0 e0 mreg \ Dynamic power management for DRAM + a2 ff fe mreg \ Dynamic clock stop controls + a3 80 80 mreg \ Toggle reduction on + a5 81 81 mreg \ "Reserved" + end-table + +1 [if] +ax ax xor +h# 12345678 # bx mov +bx 0 [ax] mov +h# 5555aaaa # 4 [ax] mov +0 [ax] dx mov +dx bx cmp <> if ascii B report ascii A report ascii D report begin again then +[then] + +\ fload ${BP}/cpu/x86/pc/ramtest.fth + +\ UMARamSetting.c +\ SetUMARam + 0 3 devfunc + a1 00 80 mreg \ Enable internal GFX + a2 ff ee mreg \ Set GFX timers + a4 ff 01 mreg \ GFX Data Delay to Sync with Clock + a6 ff 76 mreg \ Page register life timer + a7 ff 8c mreg \ Internal GFX allocation + b3 ff 9a mreg \ Disable read past write + de ff 06 mreg \ Enable CHA and CHB merge mode (but description says this value disable merging!) + end-table + + 0 3 devfunc + a1 70 40 mreg \ Set frame buffer size to 64M (8M:10, 16M:20, 32M:30, etc) - fbsize + end-table + + 1 0 devfunc + \ Reg 1b2 controls the number of writable bits in the BAR at 810 + b2 ff 70 mreg \ Offset of frame buffer, depends on size - fbsize + 04 ff 07 mreg \ Enable IO and memory access to display + end-table + + d000.0000 810 config-wl \ S.L. Base address + f000.0000 814 config-wl \ MMIO Base address + cd01 3a0 config-ww \ Set frame buffer size and CPU-relative address and enable + + 0 0 devfunc + d4 00 03 mreg \ Enable MMIO and S.L. access in Host Control device + fe 00 10 mreg \ 16-bit I/O port decoding for VGA (no aliases) + end-table + + 1 0 devfunc + b0 07 03 mreg \ VGA memory selection (coreboot uses 03, Phoenix 01. I think 03 is correct) + end-table
Modified: cpu/x86/pc/olpc/via/romreset.bth =================================================================== --- cpu/x86/pc/olpc/via/romreset.bth 2009-04-29 05:55:31 UTC (rev 1159) +++ cpu/x86/pc/olpc/via/romreset.bth 2009-04-29 08:13:15 UTC (rev 1160) @@ -349,307 +349,9 @@ 86 d6 29 mreg \ SMM and APIC Decoding: enable APIC, MSI and SMRAM A-Seg end-table
-\ Detection.c -\ DRAMCmdRate - - 0 3 devfunc - 50 11 00 mreg \ Use stable 2T command rate - end-table +fload ${BP}/cpu/x86/pc/olpc/via/demodram.fth
-\ h# 23 port80 d# 300000 wait-us
-\ FreqSetting.c : DRAMFreqSetting() - \ The following register is undocumented. coreboot has this comment: - \ Must use "CPU delay" to make sure VLINK is dis-connect - 0 7 devfunc 47 00 04 mreg end-table d# 20 wait-us - 0 3 devfunc 90 07 07 mreg end-table d# 20 wait-us \ First set DRAM Freq to invalid - 0 3 devfunc 90 07 04 mreg end-table d# 20 wait-us \ 266 MHz - 0 3 devfunc 6b d0 c0 mreg end-table d# 20 wait-us \ PLL Off - 0 3 devfunc 6b 00 10 mreg end-table d# 20 wait-us \ PLL On - 0 3 devfunc 6b c0 00 mreg end-table \ Adjustments off - 0 7 devfunc 47 04 00 mreg end-table \ disable V_LINK Auto-Disconnect - -\ h# 24 port80 d# 300000 wait-us - -\ TimingSetting.c - 0 3 devfunc - 61 ff 55 mreg \ Trfc, Trrd - 62 ff 8a mreg \ CL, Trp, Tras - 63 ff 49 mreg \ Twr, Twtr, Trtp - 64 ff 66 mreg \ Trp, Trcd - end-table - -\ DRDR_BL.c -\ DRAMDRDYsetting - 0 2 devfunc - 60 ff aa mreg \ DRDY Timing Control 1 for Read Line - 61 ff 0a mreg \ DRDY Timing Control 2 for Read Line - 62 ff 00 mreg \ Reserved, probably channel B - 63 ff aa mreg \ DRDY Timing Control 1 for Read QW - 64 ff 0a mreg \ DRDY Timing Control 2 for Read QW - 65 ff 00 mreg \ Reserved, probably channel B - 66 ff 00 mreg \ Burst DRDR Timing Control for Second cycle in burst - 67 ff 00 mreg \ Reserved, probably channel B - 54 0a 08 mreg \ Misc ctl 1 - special mode for DRAM cycles - 51 00 80 mreg \ Last step - enable DRDY timing - should the mask be f7 ? - end-table - -\ DRAMBurstLength - 0 3 devfunc - 6c 08 08 mreg \ Burst length 8 -\ DrivingSetting.c -\ DrivingODT - d0 ff 88 mreg \ Pull up/down Termination strength - d6 fc fc mreg \ DCLK/SCMD/CS drive strength - d3 fb 01 mreg \ Compensation control - enable DDR Compensation - 9e 30 10 mreg \ SRAM ODT Control 1 - 1T wait state turnaround - 9f 11 11 mreg \ SDRAM ODT Control 2 - Late extension values - d5 a0 00 mreg \ DQ/DQS Burst and ODT Range Select - disable bursts for channel A - d7 80 00 mreg \ SCMD/MA Burst - Disable SDMD/MAA burst - d5 0c 04 mreg \ Enable DRAM MD Pad ODT of Channel A High 32 bits - - 9c ff e1 mreg \ ODT Lookup table - d4 36 30 mreg \ ChannelA MD ODT dynamic-on - 9e 00 01 mreg \ Enable Channel A differential DQS Input - 9e 00 80 mreg \ Enable ODT controls - -\ DrivingDQS,DQ,CS,MA,DCLK - e0 ff ee mreg \ DQS A - e1 ff 00 mreg \ DQS B - e2 ff ac mreg \ DQ A - e3 ff 00 mreg \ DQ B - e4 ff 44 mreg \ CS A - e5 ff 00 mreg \ CS B - e6 ff ff mreg \ MCLK A - e7 ff 88 mreg \ MCKL B - e8 ff 86 mreg \ MA A - e9 ff 00 mreg \ MA B - -\ ClkCtrl.c (register tables in mainboard/via/6413e/DrivingClkPhaseData.c) -\ DutyCycleCtrl - ec ff 30 mreg \ DQS/DQ Output duty control - ee f0 00 mreg \ DCLK Output duty control - ef 30 00 mreg \ DQ CKG Input Delay - going with Phoenix value; coreboot uses 30 - -\ DRAMClkCtrl -\ WrtDataPhsCtrl - 74 07 00 mreg \ DQS Phase Offset - 75 07 00 mreg \ DQ Phase Offset - 76 ef 07 mreg \ Write data Phase control - 8c 03 03 mreg \ DQS Output Control - -\ ClkPhsCtrlFBMDDR2 - 91 07 00 mreg \ DCLK Phase - 92 07 03 mreg \ CS/CKE Phase - 93 07 04 mreg \ SCMD/MA Phase - -\ DQDQSOutputDlyCtrl - f0 ff 00 mreg \ Group A0/1 - f1 ff 00 mreg \ Group A2/3 - f2 ff 00 mreg \ Group A4/5 - f3 ff 00 mreg \ Group A6/7 - -\ DQSInputCaptureCtrl - 77 bf 8a mreg \ DQS Input Delay - Manual - 78 3f 03 mreg \ DQS Input Capture Range Control A - 7a 0f 00 mreg \ Reserved - 7b 7f 20 mreg \ Read Data Phase Control - -\ DCLKPhsCtrl - 99 1e 12 mreg \ MCLKOA[4,3,0] outputs - end-table - -\ DevInit.c -\ DRAMRegInitValue - - 0 3 devfunc - 50 ee ee mreg \ DDR default MA7 for DRAM init - 51 ee 60 mreg \ DDR default MA3 for CHB init - 52 ff 33 mreg \ DDR use BA0=M17, BA1=M18, - 53 ff 3F mreg \ DDR BA2=M19 - - 54 ff 00 mreg \ default PR0=VR0; PR1=VR1 - 55 ff 00 mreg \ default PR2=VR2; PR3=VR3 - 56 ff 00 mreg \ default PR4=VR4; PR5=VR5 - 57 ff 00 mreg \ default PR4=VR4; PR5=VR5 - - 60 ff 00 mreg \ disable fast turn-around - 65 ff D9 mreg \ AGP timer = D; Host timer = 8; - 66 ff 88 mreg \ DRAMC Queue Size = 4; park at the last bus owner,Priority promotion timer = 8 - 68 ff 0C mreg - 69 0F 04 mreg \ set RX69[3:0]=0000b - 6A ff 00 mreg \ refresh counter - 6E 07 80 mreg \ must set 6E[7],or else DDR2 probe test will fail - 85 ff 00 mreg - 40 ff 00 mreg - end-table - - 80 4a3 config-wb \ Enable toggle reduction on MA/SCMD per coreboot - -\ DRAMInitializeProc - - 0 3 devfunc - 6c 00 04 mreg \ Enable channel A only - - 54 ff 80 mreg \ Enable rank 0, disable rank 1 - 55 ff 00 mreg \ Disable ranks 2 and 3 - 40 ff 10 mreg \ Rank 0 top - 48 ff 00 mreg \ Rank 0 base - end-table - -\ h# 25 port80 d# 300000 wait-us - - DDRinit #) call - - h# 11 port80 - - 0 3 devfunc - 40 ff 00 mreg \ Rank 1 top back to 0 to work on other ranks - - 54 ff 09 mreg \ Enable rank 1 - 55 ff 00 mreg \ Disable ranks 2 and 3 - 41 ff 10 mreg \ Rank 1 top - 49 ff 00 mreg \ Rank 1 base - end-table - - DDRinit #) call - - 0 3 devfunc - 41 ff 00 mreg \ Rank 1 top back to 0 to work on other ranks - end-table - - h# 14 port80 - -0 [if] \ This is for a DIMM in the other socket - 0 3 devfunc - 54 ff 00 mreg \ Disable ranks 0,1 - 55 ff a0 mreg \ Enable Rank 2 - 42 ff 10 mreg \ Rank 2 top - 4a ff 00 mreg \ Rank 2 base - end-table - - DDRinit #) call - - 0 3 devfunc - 42 ff 00 mreg \ Rank 2 top back to 0 to work on other ranks - 54 ff 00 mreg \ Disable ranks 0,1 - 55 ff 0b mreg \ Enable Rank 3 - 43 ff 10 mreg \ Rank 3 top - 4b ff 00 mreg \ Rank 3 base - end-table - - DDRinit #) call - - 0 3 devfunc - 43 ff 00 mreg \ Rank 3 top back to 0 to work on other ranks - end-table -[then] - - 0 3 devfunc - 69 03 03 mreg \ Reinstate page optimizations (03) - FF #ranks - -\ RankMap.c -\ DRAMBankInterleave -\ (see 69 above) - 87 ff 00 mreg \ Channel B #banks or some such - FF BA -\ SizingMATypeM - - 50 ff 20 mreg \ MA Map type - ranks 0/1 type 1 - 2 bank bits, 10 column bits - 51 ff 60 mreg \ "Reserved" - 52 ff 33 mreg \ Bank interleave on A17, A18, and - 53 ff 3f mreg \ A19 (but BA2 off because 4 banks), Rank interleave on A20 and A21 - \ Different interleave bits might improve performance on some workloads - - 54 ff 89 mreg \ Rank map A 0/1 - 55 ff 00 mreg \ Rank map A 2/3 - 56 ff 00 mreg \ Rank map B ? - 57 ff 00 mreg \ Rank map B ? - - 40 ff 04 mreg \ Rank top 0 - 41 ff 08 mreg \ Rank top 1 - 42 ff 00 mreg \ Rank top 2 - 43 ff 00 mreg \ Rank top 3 - - 48 ff 00 mreg \ Rank base 0 - 49 ff 04 mreg \ Rank base 1 - 4a ff 00 mreg \ Rank base 2 - 4b ff 00 mreg \ Rank base 3 - end-table - - 20 8f60 config-wb \ DRAM Bank 7 ending address - controls DMA upstream - 0388 config-rb ax bx mov 0385 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to reg 85 - 0388 config-rb ax bx mov 8fe5 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to SB Low Top e5 - -0 [if] \ Very simple memtest -ax ax xor -h# 12345678 # bx mov -bx 0 [ax] mov -h# 5555aaaa # 4 [ax] mov -0 [ax] dx mov -dx bx cmp = if - ascii G report ascii 2 report h# 20 report -else - dx ax mov dot #) call - ascii B report ascii 2 report h# 20 report - hlt -then -[then] - - \ Low 2 bits of 86: - \ x1 to write to SMM shadow memory behind VGA - \ 00 to run - Axxxxx hits VGA in normal mode, hits shadow DRAM in SMM - \ 01 to access VGA when in SMM (data cycles only) - -\ d# 17 7 devfunc -\ e6 ff 07 mreg \ Enable Top, High, and Compatible SMM -\ end-table - - -\ DQSSearch.c -\ DRAMDQSOutputSearch - 0 3 devfunc - 70 ff 00 mreg \ Output delay - 71 ff 04 mreg - -\ DRAMDQSInputSearch - 77 ff 00 mreg \ Input delay auto - -\ FinalSetting.c -\ RefreshCounter - 6a ff 86 mreg \ Refresh interval - FF frequency - -\ DRAMRegFinalValue - 60 00 d0 mreg \ Fast turn-around - 66 30 80 mreg \ DRAMC queue = 4 (already set to 88 up above), park at last owner - 69 00 07 mreg \ Enable multiple page - 95 ff 0d mreg \ Self-refresh controls - 96 f0 a0 mreg \ Auto self-refresh stuff - fb ff 3e mreg \ Dynamic clocks - fd ff a9 mreg \ Dynamic clocks - fe ff 0f mreg \ Chips select power saving for self-refresh - ff ff 3d mreg \ DSQB input delay, SCMD enabled - 96 0f 03 mreg \ Enable self-refresh for ranks 0 and 1 - end-table - - 0 4 devfunc \ PM_table - a0 f0 f0 mreg \ Enable dynamic power management - a1 e0 e0 mreg \ Dynamic power management for DRAM - a2 ff fe mreg \ Dynamic clock stop controls - a3 80 80 mreg \ Toggle reduction on - a5 81 81 mreg \ "Reserved" - end-table - -1 [if] -ax ax xor -h# 12345678 # bx mov -bx 0 [ax] mov -h# 5555aaaa # 4 [ax] mov -0 [ax] dx mov -dx bx cmp <> if ascii B report ascii A report ascii D report begin again then -[then] - -\ fload ${BP}/cpu/x86/pc/ramtest.fth - \ UMARamSetting.c \ SetUMARam 0 3 devfunc @@ -721,6 +423,11 @@ \ 86 ff 85 mreg \ 4 MiB Top SMM Memory (80), enable top SMM memory (04), enable compatible SMM (01) end-table
+ \ Low 2 bits of 86: + \ x1 to write to SMM shadow memory behind VGA + \ 00 to run - Axxxxx hits VGA in normal mode, hits shadow DRAM in SMM + \ 01 to access VGA when in SMM (data cycles only) + h# 1c00.0000 # mem-info-pa 4 + #) mov \ Top of memory
long-offsets on
