Author: wmb Date: Tue Dec 6 08:10:51 2011 New Revision: 2736 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2736
Log: OLPC XO-3 - Added LCD power-on sequence.
Modified: cpu/arm/olpc/3.0/lcdcfg.fth
Modified: cpu/arm/olpc/3.0/lcdcfg.fth ============================================================================== --- cpu/arm/olpc/3.0/lcdcfg.fth Tue Dec 6 08:10:40 2011 (r2735) +++ cpu/arm/olpc/3.0/lcdcfg.fth Tue Dec 6 08:10:51 2011 (r2736) @@ -34,7 +34,24 @@ alias depth bpp width >bytes constant /scanline
-: init-xo-display ; : bright! ( level -- ) drop ; : backlight-on ( -- ) ; : backlight-off ( -- ) ; +: lcd-power-on ( -- ) + d# 138 gpio-set \ LCDVCC_EN + d# 135 gpio-set \ STBY# + d# 500 us + d# 130 gpio-set \ LCD_RESET# + d# 129 gpio-set \ EN_LCD_PWR + d# 50 ms \ Frame time + d# 130 gpio-clr \ LCD_RESET# (pulse low) + d# 50 us \ Pulse needs to be at least 50 us + d# 130 gpio-set \ LCD_RESET# (end of pulse) + + d# 120 ms + backlight-on +; +: init-xo-display ; \ CForth has already turned it on + +: set-source ( flag -- ) drop ; \ No DCON +true constant vga? \ No DCON, hence never frozen
