Author: rsmith Date: Wed Oct 31 00:26:46 2012 New Revision: 3400 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3400
Log: OLPC: Add tenths digit to battery temperature display
Modified: dev/olpc/kb3700/batstat.fth
Modified: dev/olpc/kb3700/batstat.fth ============================================================================== --- dev/olpc/kb3700/batstat.fth Tue Oct 30 11:37:09 2012 (r3399) +++ dev/olpc/kb3700/batstat.fth Wed Oct 31 00:26:46 2012 (r3400) @@ -1,10 +1,10 @@ : wextend ( w -- n ) dup h# 8000 and if h# ffff.0000 or then ; -\ Base unit for temperature is 1/256 degrees C -: >degrees-c 7 rshift 1+ 2/ ; \ Round to nearest degree +\ Base unit for temperature is .125 degrees C +: >milli-degrees-c 125 * 5 rshift ; : uvolt@ bat-voltage@ d# 9760 d# 32 */ ; : cur@ bat-current@ wextend d# 15625 d# 120 */ ; -: pcb-temp ambient-temp@ >degrees-c ; -: bat-temp bat-temp@ >degrees-c ; +\ : pcb-temp ambient-temp@ >milli-degrees-c ; +: bat-temp bat-temp@ >milli-degrees-c ; : soc bat-soc@ ;
string-array bat-causes @@ -79,6 +79,13 @@ if ." MPPT" then ;
+: .bat-temp + push-decimal + bat-temp + dup abs d# 50 + d# 100 / <# u# [char] . hold u#s swap sign u#> type + pop-base +; + : .% ( n -- ) push-decimal <# [char] % hold u# u#s u#> type pop-base ; : .bat ( -- ) bat-status@ ( stat ) @@ -93,7 +100,7 @@ soc .% ." " uvolt@ .milli ." V " cur@ .milli ." A " - bat-temp 2.d ." C " + .bat-temp ." C " dup 2 and if ." full " then dup 4 and if ." low " then dup 8 and if ." error " then
