Author: wmb Date: Thu Aug 11 03:35:51 2011 New Revision: 2459 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2459
Log: DRAM recalibration - added explanatory comments.
Modified: cpu/arm/mmp2/dramrecal.fth
Modified: cpu/arm/mmp2/dramrecal.fth ============================================================================== --- cpu/arm/mmp2/dramrecal.fth Thu Aug 11 02:46:27 2011 (r2458) +++ cpu/arm/mmp2/dramrecal.fth Thu Aug 11 03:35:51 2011 (r2459) @@ -1,6 +1,15 @@ \ See license at end of file purpose: Recalibrate DDR3 DRAM
+\ DDR3 DRAM requires periodic recalibration to cope with parameter drift from +\ temperature variation. The recalibration below affects both the DLL and +\ the "ZQ" driver strength. + +\ DDR3 recalibration will cause the display to glitch if done during display DMA. +\ The glitch can be avoided by doing the recal just after display frame done. +\ For example (from inside the screen driver): +\ : wait-frame-done 0 1c4 lcd! begin 1c4 lcd@ cc00.0000 tuck and = until ; + \ This code must be executed from SRAM because it touches the DRAM memory controller label ddr-recal ( r0: memctrl-va -- ) mov r1, #0x80000000 \ PHY Sync Enable (WO) - Synchronize dclk2x and dclk in the PHY
