Author: quozl Date: Mon Nov 21 01:23:36 2011 New Revision: 2694 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2694
Log: OLPC - save-mfg-data, restore-mfg-data, use new flash interface, use u:\ instead of disk:, tested on XO-1, XO-1.5, XO-1.75.
Modified: dev/olpc/spiflash/spiui.fth
Modified: dev/olpc/spiflash/spiui.fth ============================================================================== --- dev/olpc/spiflash/spiui.fth Sun Nov 20 23:23:51 2011 (r2693) +++ dev/olpc/spiflash/spiui.fth Mon Nov 21 01:23:36 2011 (r2694) @@ -123,41 +123,45 @@ drop ( sn$ ) then ( sn$ )
- " disk:" "temp place ( sn$' ) + " u:" "temp place ( sn$' )
- dup 8 > if ( sn$ ) - over 8 "temp $cat ( sn$ ) - 8 /string ( sn$' ) - " ." "temp $cat ( sn$ ) - then ( sn$ ) - "temp $cat ( ) - "temp count ( filename$ ) + dup 8 > if ( sn$ ) + over 8 "temp $cat ( sn$ ) + 8 /string ( sn$' ) + " ." "temp $cat ( sn$ ) + then ( sn$ ) + "temp $cat ( ) + "temp count ( filename$ ) ;
: save-mfg-data ( -- ) - make-sn-name ( name$ ) - ." Creating " 2dup type cr + flash-open + make-sn-name ( name$ ) + ." Creating " 2dup type cr ( name$ ) $create-file ( ihandle ) dup 0= abort" Can't create file" >r ( r: ihandle ) mfg-data-buf /flash-block ( adr len r: ihandle ) 2dup mfg-data-offset flash-read ( adr len r: ihandle ) - " write" r@ $call-method ( r: ihandle ) - r> close-dev + " write" r@ $call-method ( wlen r: ihandle ) + r> close-dev ( wlen r: ihandle ) + /flash-block <> abort" Can't write file" ( r: ihandle ) + flash-close ; : restore-mfg-data ( "filename" -- ) + flash-open reading - ifd @ fsize dup /flash-block <> if ( len ) - drop ifd @ fclose ( ) + ifd @ fsize dup /flash-block <> if ( len ) + drop ifd @ fclose ( ) true abort" File is the wrong size - should be 65536 bytes" - then ( len ) - mfg-data-buf swap ( adr len ) - 2dup ifd @ fgets drop ( adr len ) - ifd @ fclose - - flash-write-enable - mfg-data-offset flash-erase-block ( adr len ) - mfg-data-offset flash-write ( ) - flash-write-disable ( ) + then ( len ) + mfg-data-buf swap ( adr len ) + 2dup ifd @ fgets drop ( adr len ) + ifd @ fclose ( adr len ) + flash-write-enable ( adr len ) + mfg-data-offset flash-erase-block ( adr len ) + mfg-data-offset flash-write ( ) + flash-write-disable ( ) + flash-close ( ) ; [then]
