Author: wmb Date: Wed Aug 10 01:54:30 2011 New Revision: 2456 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2456
Log: Alex - turn off serial output.
Added: dev/null2.fth dev/nulluart.fth Modified: cpu/x86/pc/alex/config.fth cpu/x86/pc/alex/devices.fth cpu/x86/pc/alex/fw.bth cpu/x86/pc/alex/usb.fth
Modified: cpu/x86/pc/alex/config.fth ============================================================================== --- cpu/x86/pc/alex/config.fth Wed Aug 10 01:13:17 2011 (r2455) +++ cpu/x86/pc/alex/config.fth Wed Aug 10 01:54:30 2011 (r2456) @@ -5,12 +5,12 @@
create coreboot-loaded create coreboot-qemu -create debug-startup +\ create debug-startup
create use-timestamp-counter create use-tsc-timing
-create serial-console +\ create serial-console
\ In virtual mode, OFW runs with the MMU on. The advantages are \ that OFW can automatically locate itself out of the way, at the
Modified: cpu/x86/pc/alex/devices.fth ============================================================================== --- cpu/x86/pc/alex/devices.fth Wed Aug 10 01:13:17 2011 (r2455) +++ cpu/x86/pc/alex/devices.fth Wed Aug 10 01:54:30 2011 (r2456) @@ -81,16 +81,18 @@ fload ${BP}/cpu/x86/pc/isatick.fth \ Use ISA timer as the alarm tick timer fload ${BP}/cpu/x86/pc/olpc/timertest.fth \ Selftest for PIT timer
+fload ${BP}/dev/pci/isaall.fth +devalias mouse /isa/8042/mouse + +fload ${BP}/cpu/x86/pc/tsccal1.fth + [ifdef] resident-packages support-package: 16550 fload ${BP}/dev/16550pkg/16550.fth \ Serial port support package end-support-package [then]
-fload ${BP}/dev/pci/isaall.fth -devalias mouse /isa/8042/mouse - -fload ${BP}/cpu/x86/pc/tsccal1.fth +fload ${BP}/dev/null2.fth
0 0 hex mem-uart-base (u.) " /" begin-package 4 encode-int 0 encode-int encode+ " interrupts" property @@ -99,7 +101,13 @@ fload ${BP}/dev/16550pkg/isa-int.fth end-package devalias com1 /serial:115200 -: com1 ( -- adr len ) " com1" ; ' com1 to fallback-device +: com1 ( -- adr len ) " com1" ; +[ifdef] serial-console +' com1 to fallback-device +[else] +: devnull ( -- adr len ) " /null" ; +' devnull to fallback-device +[then]
0 0 " i70" " /isa" begin-package \ Real-time clock node fload ${BP}/dev/ds1385r.fth @@ -166,8 +174,13 @@ ;
fload ${BP}/cpu/x86/inoutstr.fth \ Multiple I/O port read/write + +[ifdef] serial-console fload ${BP}/dev/isa/diaguart.fth \ ISA COM port driver fload ${BP}/forth/lib/sysuart.fth \ Use UART for key and emit +[else] +fload ${BP}/dev/nulluart.fth \ Null UART driver +[then]
0 value keyboard-ih 0 value screen-ih
Modified: cpu/x86/pc/alex/fw.bth ============================================================================== --- cpu/x86/pc/alex/fw.bth Wed Aug 10 01:13:17 2011 (r2455) +++ cpu/x86/pc/alex/fw.bth Wed Aug 10 01:54:30 2011 (r2456) @@ -210,8 +210,8 @@ fload ${BP}/cpu/x86/pc/alex/yuv2rgb.fth \ YUV2 to RGB conversion fload ${BP}/cpu/x86/pc/alex/vstest.fth \ Video stream test helpers
-\ false to stand-init-debug? -true to stand-init-debug? +false to stand-init-debug? +\ true to stand-init-debug?
hex stand-init-debug? [if] @@ -244,13 +244,9 @@
: probe-all ( -- ) " probe-" do-drop-in - ." probe-pci" cr -\ debug-me probe-pci - probe-usb - report-net - report-disk report-pci-fb + silent-probe-usb ;
\ This reduces processor use when waiting for a key. It helps @@ -261,13 +257,15 @@ : startup ( -- ) standalone? 0= if exit then
- ." nvramrc" cr - use-nvramrc? if nvramrc safe-evaluate then + use-nvramrc? if nvramrc safe-evaluate then
auto-banner? if " Probing" ?type probe-all install-mux-io -\ " Install console" ?type install-console +[ifndef] serial-console + fallback-in-ih remove-input + fallback-out-ih remove-output +[then] \ ?usb-keyboard banner then @@ -285,6 +283,7 @@ ." See " blue-letters ." http://wiki.laptop.org/go/Forth_Lessons" black-letters cr cr + ." Type menu to run diagnostics" cr
quit ;
Modified: cpu/x86/pc/alex/usb.fth ============================================================================== --- cpu/x86/pc/alex/usb.fth Wed Aug 10 01:13:17 2011 (r2455) +++ cpu/x86/pc/alex/usb.fth Wed Aug 10 01:54:30 2011 (r2456) @@ -41,7 +41,13 @@ pwd$ $nopage-show-devs then ; +: show-usb ( -- ) + ." USB2 devices:" cr + " /" ['] (show-usb2) scan-subtree
+ ." USB1 devices:" cr + " /" ['] (show-usb1) scan-subtree +; : silent-probe-usb ( -- ) " /" ['] (probe-usb2) scan-subtree " /" ['] (probe-usb1) scan-subtree @@ -49,12 +55,7 @@ ; : probe-usb ( -- ) silent-probe-usb - - ." USB2 devices:" cr - " /" ['] (show-usb2) scan-subtree - - ." USB1 devices:" cr - " /" ['] (show-usb1) scan-subtree + show-usb ; alias p2 probe-usb
Added: dev/null2.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ dev/null2.fth Wed Aug 10 01:54:30 2011 (r2456) @@ -0,0 +1,41 @@ +\ See license at end of file +purpose: Null I/O package - discards output, provides no input + +dev / +new-device + +" null" device-name + +: open ( -- flag ) true ; +: close ( -- ) ; +: size ( -- ud ) 0 0 ; +: seek ( ud -- error? ) or ; \ error if ud is not 0 0 +: write ( adr len -- actual ) nip ; \ Return actual = len +: read ( adr len -- actual ) 2drop -2 ; \ Return -2, indicating no input + +finish-device +device-end + +\ LICENSE_BEGIN +\ Copyright (c) 2006 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Added: dev/nulluart.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ dev/nulluart.fth Wed Aug 10 01:54:30 2011 (r2456) @@ -0,0 +1,47 @@ +\ See license at end of file +purpose: Null diagnostic UART driver + +: inituarts ( -- ) ; +: ukey? ( -- flag ) false ; +: uemit? ( -- flag ) false ; +: uemit ( char -- ) drop ; +: ukey ( -- char ) drop ; +: ubreak? ( -- flag ) false ; +: clear-break ( -- ) ; + +: install-uart-io ( -- ) + ['] lf-pstr is newline-pstring + ['] false is key? + ['] 0 is (key + ['] drop is (emit + ['] default-type is (type + ['] emit1 is emit + ['] type1 is type + ['] crlf is cr + ['] true is (interactive? + ['] cancel is light +; + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
