Author: wmb Date: Fri Jun 17 09:52:21 2011 New Revision: 2292 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2292
Log: OLPC trac #10895 - OFW end of SP-PS2 communications protocol.
Added: cpu/arm/olpc/spcmd.fth
Added: cpu/arm/olpc/spcmd.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/spcmd.fth Fri Jun 17 09:52:21 2011 (r2292) @@ -0,0 +1,171 @@ +\ See license at end of file +purpose: Communication protocol for application processor to security processor + +\ Interface from pckbd.fth to i8042.fth: +\ set-port ( port# -- ) \ Selects keyboard (port#=0) or mouse (port#=1) +\ get-data ( -- data | -1 ) \ Returns a keyboard or mouse byte, or -1 if none after one second +\ get-data? ( -- false | data true ) \ Non-blocking version of get-data +\ clear-out-buf ( -- ) \ Drains pending data, waiting until 120 ms elapses with no data. Built from get-data? +\ put-get-data ( cmd -- data | -1 ) \ Sends cmd and waits for one response byte +\ Used only by "echo?", which is not called on OLPC. +\ put-data ( data -- ) \ Sends a byte to the keyboard or mouse +\ Used only by "cmd". "cmd" is used by set-scan-set, default-disable-kbd, enable-scan, set-leds, toggle-leds, +\ kbd-reset, (obsolete) olpc-set-ec-keymap. set-scan-set is used only by commented-out code guarded by +\ the non-defined ifdef "fix-keyboard". default-disable-kbd is called only by get-initial-state (NC on OLPC). +\ enable-scan is NC on OLPC. set-leds is called by toggle-leds with is called when you press numlock or +\ scrolllock or capslock, none of which the OLPC keyboard has. + +0 0 " d4290000" " /" begin-package \ AP-SP interface the WTM command queue + +headerless + +" ap-sp" device-name + +0 0 encode-bytes + " olpc,ap-sp" encode-string encode+ +" compatible" property + +my-address my-space h# 1000 encode-reg +" reg" property + +1 " #address-cells" integer-property +0 " #size-cells" integer-property + +: encode-unit ( phys -- adr len ) push-hex (u.) pop-base ; +: decode-unit ( adr len -- phys ) push-hex $number if 0 then pop-base ; + +\ Channel#(port#) Meaning +\ 0 Keyboard +\ 1 Touchpad + +2 constant #ports +#ports constant #queues + +d# 16 constant /q + +0 value queue# +#queues /n* buffer: heads : head ( -- adr ) heads queue# na+ ; +#queues /n* buffer: tails : tail ( -- adr ) tails queue# na+ ; + +#queues /q * buffer: qs : q ( adr -- ) qs queue# /q * + ; + +/q 1- value q-end + +: init-queues ( -- ) + #queues 0 do + i to queue# + 0 head ! 0 tail ! /q 1- to q-end + loop +; +: inc-q-ptr ( pointer-addr -- ) + dup @ q-end >= if 0 swap ! else /c swap +! then +; + +: select-queue ( channel# -- error? ) + to queue# + queue# #queues >= +; + +: enque ( new-entry channel# -- ) + select-queue if drop exit then ( new-entry ) + tail @ head @ 2dup > if - q-end else 1- then ( new-entry tail head ) + <> if q tail @ ca+ c! tail inc-q-ptr else drop then +; + +: deque? ( channel# -- false | entry true ) + select-queue if false exit then + lock[ + head @ tail @ <> if + q head @ ca+ c@ head inc-q-ptr true + else + false + then + ]unlock +; + +0 value reg-base +: reg@ ( offset -- l ) reg-base + l@ ; +: reg! ( l offset -- ) reg-base + l! ; + +: data? ( -- flag ) h# c8 reg@ 1 and ; +: send-rdy ( -- ) h# ff00 h# 40 reg! ; +: poll ( -- ) + lock[ + data? if + h# 80 reg@ wbsplit enque + 1 h# c8 reg! + send-rdy + then + ]unlock +; + +0 instance value port# +: set-port ( port# -- ) to port# ; +: get-data? ( -- false | data true ) + port# deque? ( false | data true ) + poll +; +: get-data ( -- data | -1 ) \ Wait for data from our device + d# 1000 0 do + get-data? if unloop exit then ( data ) + 1 ms + loop + true \ abort" Timeout waiting for data from device" +; +\ Wait until the device stops sending data +: clear-out-buf ( -- ) begin d# 120 ms get-data? while drop repeat ; + +0 value open-count +: open ( -- flag ) + open-count 0= if + my-address my-space h# 1000 " map-in" $call-parent is reg-base + data? 0= if send-rdy then + then + open-count 1+ to open-count + true +; +: close ( -- ) + open-count 1 = if + reg-base h# 1000 " map-out" $call-parent 0 is reg-base + then + open-count 1- 0 max to open-count +; + +: put-data ( byte -- ) port# bwjoin h# 40 reg! ; +: put-get-data ( cmd -- data | -1 ) put-data get-data ; + +new-device + " " " 0" set-args + fload ${BP}/dev/pckbd.fth +finish-device + +new-device + " " " 1" set-args + fload ${BP}/dev/ps2mouse.fth +finish-device + +end-package + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
