Author: wmb Date: 2009-10-03 00:09:44 +0200 (Sat, 03 Oct 2009) New Revision: 1391
Modified: cpu/x86/pc/olpc/via/startcominit.fth Log: Via cominit - working toward eliminating the CMOS startup delay.
Modified: cpu/x86/pc/olpc/via/startcominit.fth =================================================================== --- cpu/x86/pc/olpc/via/startcominit.fth 2009-10-02 22:08:40 UTC (rev 1390) +++ cpu/x86/pc/olpc/via/startcominit.fth 2009-10-02 22:09:44 UTC (rev 1391) @@ -38,6 +38,7 @@ \ Do this outside the if..then so the setup is consistent in all cases d# 17 0 devfunc 40 44 44 mreg \ Enable I/O Recovery time (40), Enable ports 4d0/4d1 for edge/level setting (04) + 43 0f 0b mreg \ Enable PCI delayed transactions (08), Write transaction timer (02), Read transaction timer (01) 4c c0 40 mreg \ Set I/O recovery time to 2 bus clocks 59 ff 1c mreg \ Keyboard (ports 60,64) and ports 62,66 on LPC bus (EC) 5c ff 68 mreg \ High byte (68) of PCS0 @@ -47,10 +48,19 @@ 67 10 10 mreg \ PCS0 to LPC Bus end-table
+ d# 17 0 devfunc + 70 fb 82 mreg \ CPU to PCI flow control - CPU to PCI posted write, Enable Delay Transaction + end-table + +h# 83 # al mov al h# 74 # out h# 75 # al in \ check byte - should be ~board-id +ax bx mov + \ This delay is empirically necessary before reading CMOS - minimum is 36000 - about 50 ms \ Before the delay has elapsed, the CMOS RAM returns 0 instead of the stored value. d# 40000 wait-us
+h# 88 # al mov al h# 74 # out bx ax mov al h# 75 # out \ Test for CMOS read timing + \ As an optimization to avoid long waits for the EC to respond, read the board ID \ that is cached in CMOS RAM. This might not in fact be an optimization in light \ of the above delay ...
