Author: wmb Date: Sun Oct 16 00:23:26 2011 New Revision: 2610 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2610
Log: Core - added voc>phandle and phandle>voc defer words, defaulting to noop, to decouple the representation of a phandle from the implementation choice of the address of a Forth wordlist. There is no current need for that decoupling, but the implementation is cleaner with the change. The change should have no functional impact.
Modified: ofw/core/ofwcore.fth
Modified: ofw/core/ofwcore.fth ============================================================================== --- ofw/core/ofwcore.fth Sat Oct 15 23:56:30 2011 (r2609) +++ ofw/core/ofwcore.fth Sun Oct 16 00:23:26 2011 (r2610) @@ -673,6 +673,9 @@
headers
+defer voc>phandle ' noop to voc>phandle +defer phandle>voc ' noop to phandle>voc + \ TODO \ Don't use the system search order; use a private stack \ $find searches through the private stack @@ -680,14 +683,14 @@ \ Either implement a true breadth-first search or don't specify it.
2 actions -action: drop context token@ ; -action: drop context token! definitions ; +action: drop context token@ voc>phandle ; +action: drop phandle>voc context token! definitions ; create current-device use-actions
headerless : ufield \ name ( offset size -- offset' ) create over , + - does> @ current-device >body >user + + does> @ current-device phandle>voc >body >user + ;
\ Notes for a more abstract searching mechanism: @@ -715,14 +718,17 @@ constant /devnode-extra
headers -: >parent ( node -- parent-node ) >voc-link link@ ; +: >parent ( node -- parent-node ) >voc-link link@ voc>phandle ; : parent-device ( -- parent-node ) current-device >parent ;
+: (select-package) ( phandle -- ) phandle>voc execute ; +: (push-package) ( phandle -- ) also (select-package) ; +: (pop-package) ( phandle -- ) previous ; : push-package ( phandle -- ) dup 0= if ." Attempting to push null package!!!" abort then - also execute definitions + (push-package) definitions ; -: pop-package ( -- ) previous definitions ; +: pop-package ( -- ) (pop-package) definitions ; : push-device ( acf -- ) to current-device ;
: pop-device ( -- ) @@ -945,7 +951,7 @@ : >initial-value ( pfa -- adr ) @ my-self if \ Use current instance's package if there is a current instance - my-voc also execute initial-values previous + my-voc (push-package) initial-values (pop-package) else \ Otherwise use the active package initial-values then @@ -1045,9 +1051,9 @@ \ to a non-existent instance.
: destroy-instance ( -- ) - also my-voc execute ( ) + my-voc (push-package) ( ) '#values @ '#buffers @ negate ( value-size variable-size ) - previous ( value-size variable-size ) + (pop-package) ( value-size variable-size ) deallocate-instance
; @@ -1150,6 +1156,9 @@ : $vexecute? ( adr len voc-acf -- true | ??? false) (search-wordlist) if execute false else true then ; +: $package-execute? ( adr len phandle -- true | ??? false) + phandle>voc (search-wordlist) if execute false else true then +; : $vexecute ( adr len voc-acf -- ?? ) $vexecute? drop ;
headers @@ -1227,7 +1236,7 @@
: my-#adr-cells ( -- n ) my-self if \ Use current instance's package if there is a current instance - my-voc also execute '#adr-cells @ previous + my-voc (push-package) '#adr-cells @ (pop-package) else \ Otherwise use the active package '#adr-cells @ then @@ -1359,7 +1368,7 @@
: property ( value-adr,len name-adr,len -- ) my-self if - context token@ >r my-voc execute + context token@ >r my-voc (select-package) (property) r> context token! else @@ -1515,7 +1524,7 @@
headers : package-execute ( ?? adr len -- ?? ) - current-device $vexecute? abort" Package method not found" + current-device $package-execute? abort" Package method not found" ; headerless
@@ -1788,8 +1797,8 @@ get-unit 0= if ( unit-str ) ." @" unit-str>phys ( phys.lo .. phys.hi ) - " encode-unit" parent-device ( phys.lo .. phys.hi adr,len ph ) - $vexecute? if ( phys.lo .. phys.hi ) + " encode-unit" parent-device ( phys.lo .. phys.hi adr,len phandle ) + $package-execute? if ( phys.lo .. phys.hi ) '#adr-cells @ if .nh then ( phys.lo .. phys.next ) '#adr-cells @ 1- 0 max 0 ?do ." ," .nh loop ( ) else @@ -2132,7 +2141,7 @@ ;
: get-package-property ( adr len phandle -- true | adr' len' false ) - also execute get-property previous + (push-package) get-property (pop-package) ;
\ Used when executing from an open package instance. Finds a property @@ -2273,7 +2282,7 @@ ;
: apply-method ( adr len -- no-such-method? ) - my-voc fm-hook ['] $vexecute? catch ?dup if ( x x x errno ) + my-voc fm-hook ['] $package-execute? catch ?dup if ( x x x errno ) \ executing method caused an error nip nip nip ( errno ) then ( ??? false | true | errno ) @@ -2771,7 +2780,7 @@ " @" encode-bytes+ 2>r ( phys .. ) ( R: $ )
" encode-unit" parent-device ( phys .. adr,len phandle ) ( R: $ ) - $vexecute? if ( phys .. ) ( R: $ ) + $package-execute? if ( phys .. ) ( R: $ )
2r> ( phys .. adr,len ) ( R: ) '#adr-cells @ if encode-number+ then ( phys . adr,len' ) @@ -3164,9 +3173,9 @@ headerless : (trace) ( adr len phandle -- adr len phandle ) >r >r >r .s r> r> ( adr len ) ( r: phandle ) - also r@ execute ( adr len ) ( r: phandle ) + r@ (push-package) ( adr len ) ( r: phandle ) " name" get-property ( adr len value-str false ) ( r: phandle ) - previous ( adr len value-str false ) ( r: phandle ) + (pop-package) ( adr len value-str false ) ( r: phandle ) drop get-encoded-string type ( adr len ) ( r: phandle ) ." : " 2dup type space cr ( adr len ) ( r: phandle ) r> ( adr len phandle ) @@ -4051,7 +4060,7 @@ ;
: setnode ( nodeid | 0 -- ) - dup 0= if drop ['] root-node then also execute + dup 0= if drop ['] root-node then (push-package) ;
\ : copyout ( buf adr len -- len ) >r swap r@ cmove r> ; @@ -4124,7 +4133,7 @@ false ( false ) then then ( cstr ) - previous + (pop-package) ; : .cstr ( cstr -- ) begin dup c@ ?dup while emit 1+ repeat drop ;
@@ -4150,10 +4159,10 @@ setnode ( ) 0 'child ( last-nodeid &next-nodeid ) begin get-token? while ( last-nodeid next-nodeid ) - nip dup execute ( next-nodeid ) + nip dup (select-package) ( next-nodeid ) 'peer ( last-nodeid' &next-nodeid ) repeat ( last-nodeid' ) - previous ( nodeid ) + (pop-package) ( nodeid ) ;
: peer ( phandle -- phandle' ) @@ -4166,8 +4175,8 @@ then ( nodeid )
\ Select the first child of our parent - dup >parent also execute ( nodeid ) - 'child token@ execute ( nodeid ) + dup >parent (push-package) ( nodeid ) + 'child token@ (select-package) ( nodeid )
dup current-device = if ( nodeid ) \ Argument node is first child of parent; return "no more nodes" @@ -4181,7 +4190,7 @@ repeat ( nodeid ) 2drop current-device ( nodeid' ) then ( nodeid | 0 ) - previous ( nodeid | 0 ) + (pop-package) ( nodeid | 0 ) ;
: parent ( phandle -- phandle' ) @@ -4203,7 +4212,7 @@ 2drop -1 ( -1 ) then ( len | -1 ) then ( len | -1 ) - previous ( len | -1 ) + (pop-package) ( len | -1 ) ;
: instance-to-package ( ihandle -- phandle ) ihandle>phandle ; @@ -4228,7 +4237,7 @@ 2drop 2drop -1 ( -1 ) then ( len|-1 ) then ( len|-1 ) - previous ( len|-1 ) + (pop-package) ( len|-1 ) ;
: nextprop ( buf prev phandle -- 1|0|-1 ) @@ -4259,7 +4268,7 @@ 2drop 2drop -1 ( -1 ) then ( len|-1 ) then ( len|-1 ) - previous + (pop-package) ;
: finddevice ( cstr -- phandle ) cscount locate-device ?dup drop ; @@ -4325,8 +4334,8 @@
: append-my-unit ( phys.. -- ) " @" canon+ - " encode-unit" parent-device ( phys.. adr,len ph ) - $vexecute? if ( phys.. ) + " encode-unit" parent-device ( phys.. adr,len phandle ) + $package-execute? if ( phys.. ) '#adr-cells @ if (nh.) canon+ then ( phys.lo .. phys.next ) '#adr-cells @ 1- 0 max 0 ?do ( phys.lo .. phys.next ) " ," canon+ (nh.) canon+ ( phys.lo .. phys.next' ) @@ -4424,13 +4433,13 @@ headerless : ?delete-address ( adr len -- adr len ) my-self if ( adr len ) - also my-voc execute ( adr len ) + my-voc (push-package) ( adr len ) " address" get-property 0= if ( adr len value-adr,len ) get-encoded-int 2 pick = if ( adr len ) " address" delete-property ( adr len ) then ( adr len ) then ( adr len ) - previous ( adr len ) + (pop-package) ( adr len ) then ( adr len ) ; headers
