Author: wmb Date: Mon Dec 3 08:07:43 2012 New Revision: 3468 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3468
Log: OLPC XO-4 - Improved access methods for HDMI EDID info.
Modified: cpu/arm/olpc/gpio-i2c.fth
Modified: cpu/arm/olpc/gpio-i2c.fth ============================================================================== --- cpu/arm/olpc/gpio-i2c.fth Mon Dec 3 08:05:56 2012 (r3467) +++ cpu/arm/olpc/gpio-i2c.fth Mon Dec 3 08:07:43 2012 (r3468) @@ -42,7 +42,7 @@
0 0 encode-bytes cam-sda-gpio# 0 encode-gpio - cam-scl-gpio# 0 encode-gpio + cam-scl-gpio# 0 encode-gpio " gpios" property
0 instance value slave-address @@ -144,22 +144,59 @@ " hdmi-ddc" device-name h# 50 1 reg : close ( -- ) ; - h# 100 buffer: hdmi-edid - - : get-edid ( -- adr len ) - hdmi-edid h# 100 0 " i2c-read" $call-parent - hdmi-edid h# 100 + h# 80 constant /edid-chunk + 0 value edid + 0 value /edid + + : release-edid ( -- ) + edid /edid free-mem ( ) + 0 to /edid 0 to edid ( ) ; + : open ( -- okay? ) my-unit " set-address" $call-parent - hdmi-edid h# 100 0 " i2c-read" ['] $call-parent catch if - 2drop 3drop false - else - true + /edid-chunk to /edid + /edid alloc-mem to edid + + edid /edid 0 " i2c-read" ['] $call-parent catch if ( x x x x x ) + 2drop 3drop ( ) + release-edid false exit ( -- false ) + then + + \ Basic sanity check to make sure it's an EDID + edid " "(00ffffffffffff00)" comp if ( ) + release-edid false exit ( -- false ) then + + \ We could (should) do a checksum here... + + \ If there are no extensions, exit now, successfully + edid d# 126 + c@ dup 0= over h# ff = or if ( #exts ) + drop true exit ( -- true ) + then ( #exts ) + + \ Otherwise make the buffer larger to accomodate the extensions ... + 1+ /edid-chunk * to /edid ( ) + edid /edid resize-memory if ( adr' ) + drop ( ) + 0 to /edid 0 to edid ( ) + false exit ( ) + then ( adr ) + to edid ( ) + + \ ... and read the extensions + edid /edid /edid-chunk /string /edid-chunk ( adr len offset ) + " i2c-read" ['] $call-parent catch if ( x x x x x ) + 2drop 3drop ( ) + release-edid false exit ( -- false ) + then + + true ; - : edid$ ( -- adr len ) hdmi-edid h# 100 ; + : edid$ ( -- adr len ) edid /edid ; finish-device finish-device [then] device-end + +devalias i2c6 /hdmi-i2c
