Author: wmb Date: Tue Aug 3 21:52:21 2010 New Revision: 1906 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1906
Log: svn ignore *.public
Added: cpu/x86/pc/olpc/keyinsert.fth Modified: cpu/x86/pc/olpc/ (props changed)
Added: cpu/x86/pc/olpc/keyinsert.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/x86/pc/olpc/keyinsert.fth Tue Aug 3 21:52:21 2010 (r1906) @@ -0,0 +1,172 @@ +purpose: Inject additional keys into manufacturing data on non-secured machine +\ See license at end of file + +\ This key insertion program is for use in manufacturing before the machines +\ have been secured, i.e. before the wp tag is created. + +\ Search for !!! for things that may need to change for different deployments + +\ !!! Change the list of SKUs according to which ones should receive the new keys +: wrong-sku? ( -- flag ) + " P#" find-tag 0= if true exit then ( pn$ ) + + -null ( pn$' ) + 2dup " 1CL1BZP0KD6" $= if 2drop false exit then ( pn$ ) \ UY BYD LiFePO4 + 2dup " 1CL11ZP0KD7" $= if 2drop false exit then ( pn$ ) \ UY GP NiMH + 2dup " 1CL11ZP0KD9" $= if 2drop false exit then ( pn$ ) \ UY GP LiFePO4 + 2dup " 1CL1B000003" $= if 2drop false exit then ( pn$ ) \ Preproduction XO-1.5 +[ifdef] test-me + 2dup " 1CL11ZU0KDB" $= if 2drop false exit then ( pn$ ) \ US for testing +[then] + 2drop + + true +; + +\ !!! Change the key list according to which keys the deployment wants +: new-key-list$ ( -- ) " a1 d1 o1 s1 t1 w1 " ; + +\ !!! Change the pattern according to the location of key data files +: get-key-file ( keyname$ -- false | value$ true ) +\ " ext:\%s.public" \ For an SD card formatted with EXT2 (capable of handling long names) + " u:\%s.pub" \ For a USB driver formatted with FAT (8.3 filename restriction) + sprintf $read-file 0= +; + +: keyject-expired? ( -- flag ) false ; + +\ True if the all the requested tags are already present. +\ This prevents endless looping. +: already-injected? ( -- flag ) + new-key-list$ begin dup while ( $ ) + bl left-parse-string ( $' name$ ) + find-tag if ( $ value$ ) + 2drop ( $ ) + else ( $ ) + 2drop false exit + then ( $ ) + repeat ( $ ) + 2drop true +; + +: inject-key ( keyname$ -- ) + 2dup get-key-file if ( keyname$ value$ ) + 2over ram-find-tag if ( keyname$ value$ oldvalue$ ) + 2 pick <> if ( keyname$ value$ oldvalue$ ) + 3drop ( keyname$ ) + ." Warning: inconsistent old tag length for " type cr ( ) + exit + then ( keyname$ value$ oldvalue-adr ) + >r 2tuck r> swap move ( valu$ keyname$ ) + green-letters + ." Replaced " type cr ( value$ ) + black-letters + else ( keyname$ value$ ) + 2swap ( value$ keyname$ ) + 2over 2over ( value$ keyname$ value$ keyname$ ) + ($add-tag) ( value$ keyname$ ) + green-letters + ." Added " type cr ( value$ ) + black-letters + then ( value$ ) + free-mem ( ) + else ( keyname$ ) + ." Warning: Can't find a dropin module for " type cr ( ) + then ( ) +; + +: inject-keys ( -- ) + get-mfg-data + new-key-list$ begin dup while ( $ ) + bl left-parse-string ( $' name$ ) + inject-key ( $ ) + repeat ( $ ) + 2drop ( ) + (put-mfg-data) ( ) +; + +: keyject-error ( msg$ -- ) + cr + red-letters ." Not injecting because: " type cr black-letters + cr +; + +: do-keyject? ( -- flag ) + wrong-sku? if + " Wrong SKU" keyject-error + false exit + then + keyject-expired? if + " Date Expired" keyject-error + false exit + then + already-injected? if + " Keys Already Present" keyject-error + false exit + then + true +; + +: ac-connected? ( -- flag ) bat-status@ h# 10 and 0<> ; + +\ Empirically, a weak-but-present battery can present the "trickle charge" (80) +\ but not present the "present" bit (01). +: battery-present? ( -- flag ) bat-status@ h# 81 and 0<> ; + +\ Similarly, a weak-but-present battery can present the "trickle charge" (80) +\ but not present the "battery low" bit (04). +: battery-strong? ( -- flag ) bat-status@ h# 84 and 0= ; + +: wait-enough-power ( -- ) + ac-connected? 0= if + ." Please connect the AC adapter to continue..." + begin d# 100 ms ac-connected? until + cr + then + battery-present? 0= if + ." Please insert a well-charged battery to continue..." + begin d# 100 ms battery-present? until + cr + then + battery-strong? 0= if + ." The battery is low. Please insert a charged one to continue..." + begin d# 100 ms battery-present? battery-strong? and until + then +; + +: ?keyject ( -- ) + visible + green-letters cr ." Security Key Injector" cr cr black-letters + do-keyject? if + wait-enough-power + flash-write-enable + inject-keys + flash-write-disable \ Should reboot + then +; + +?keyject + +\ LICENSE_BEGIN +\ Copyright (c) 2010 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
