Author: pgf Date: 2010-01-21 07:17:12 +0100 (Thu, 21 Jan 2010) New Revision: 1679
Modified: cpu/x86/pc/olpc/via/runin.fth Log: changes from chia-hsiu: fix handling of KA tag, for comparision purposes, adjust rtc +/- limit, and add support for the "repass" file. i think we need to understand a little better what this is for.
Modified: cpu/x86/pc/olpc/via/runin.fth =================================================================== --- cpu/x86/pc/olpc/via/runin.fth 2010-01-19 01:17:16 UTC (rev 1678) +++ cpu/x86/pc/olpc/via/runin.fth 2010-01-21 06:17:12 UTC (rev 1679) @@ -18,14 +18,14 @@
d# 128 buffer: mb-buf : mb$ mb-buf count ;
-: get-mb-tags ( --) +: get-mb-tags ( -- ) " B#" find-tag if ?-null then mb-buf place ;
-: set-tag-assy ( --) +: set-tag-assy ( -- ) get-mb-tags
clear-mfg-buf @@ -178,7 +178,7 @@ 2>r 2over 2r@ $= if ( value$ key$ r: old-value$' ) 2drop 2drop 2r> 2drop ( ) else ( value$ key$ r: old-value$' ) - type ." tag changed!" cr ( value$ r: old-value$' ) + type ." tag changed!" cr ( value$ r: old-value$' ) ." Old: " 2r> show-tag cr ( value$ ) ." New: " show-tag cr ( ) do-tag-error @@ -188,12 +188,28 @@ then ;
+: replace-ka-value ( rem$ value$ key$ -- rem$ file-data$ key$ ) + 2swap 2dup 8 min ka-dir$ " %s%s" sprintf ( rem$ key$ value$ filename$ ) + $read-file if ( rem$ key$ value$ ) + ." ERROR: No KA tag file for " type cr ( rem$ key$ ) + true abort" KA file not found" ( rem$ key$ ) + 2drop ( rem$ ) + else ( rem$ key$ value$ file-data$ ) + 2swap 2drop ( rem$ key$ file-data$ ) + 2swap ( rem$ file-data$ key$ ) + then +; + : parse-tags ( adr len -- ) begin dup while ( adr len ) linefeed left-parse-string ( rem$ line$ ) ?remove-cr ( rem$ line$ ) [char] : left-parse-string ( rem$ value$ key$ ) dup 2 = if ( rem$ value$ key$ ) + \ catch value from http, if KA tag + 2dup " KA" $= if ( rem$ value$ key$ ) + replace-ka-value ( rem$ value$' key$ ) + then handle-tag ( rem$ ) else ( rem$ value$ key$ ) 4drop ( rem$ ) @@ -201,6 +217,7 @@ repeat ( adr len ) 2drop ( ) ; + : format-date ( s m h d m y -- adr len ) push-decimal >r >r >r >r >r >r @@ -243,7 +260,7 @@ kbc-on ;
-d# 4 constant rtc-threshold +d# 180 constant rtc-threshold \ yes, really. 3 minutes 0 value ntp-seconds 0 value rtc-seconds : .clocks ( -- ) @@ -350,9 +367,12 @@
: finish-final-test ( -- )
- " del int:\runin\olpc.fth" ['] eval catch - " copy int:\runin\repass.fth int:\runin\olpc.fth" ['] eval catch - " del int:\runin\repass.fth" ['] eval catch + " int:\runin\final.fth" $safe-delete + " int:\runin\repass.fth" 2dup $file-exists? if + " int:\runin\final.fth" $copy + else + 2drop + then
wait-connections
@@ -369,6 +389,8 @@ ." Submitting results .. " final-result cifs-disconnect ." Done" cr + + " int:\runin\repass.fth" $safe-delete
\ need to delete target, due to #9957 " int:\runin\final.fth.sav" $safe-delete
