Author: quozl Date: Tue Nov 15 05:21:53 2011 New Revision: 2690 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2690
Log: OLPC trac 11427 - test-all stopped working at the first device that had no reg property, caused by stack imbalance in most-tests premature exit paths
Modified: ofw/core/ofwcore.fth
Modified: ofw/core/ofwcore.fth ============================================================================== --- ofw/core/ofwcore.fth Tue Nov 15 02:14:16 2011 (r2689) +++ ofw/core/ofwcore.fth Tue Nov 15 05:21:53 2011 (r2690) @@ -3278,18 +3278,18 @@ ' (hold-message) to hold-message
: most-tests ( -- exit? ) - " selftest" current-device (search-wordlist) if ( xt ) + " selftest" current-device (search-wordlist) if ( xt )
- drop ( ) + drop ( )
\ We only want to execute the selftest routine if the device has \ a "reg" property. This eliminates the execution of selftest \ routines for "wildcard" devices like st and sd.
- " reg" get-property if exit then 2drop ( ) + " reg" get-property if false exit then 2drop ( )
\ We sometimes want to skip the testing of certain devices. - current-device skip-test? if exit then ( ) + current-device skip-test? if false exit then ( )
??cr ." Testing " pwd " selftest" current-device ( method-adr,len phandle ) @@ -3317,16 +3317,10 @@ then ( exit? ) ;
-\ "action-acf" is executed for each device node in the subtree -\ rooted at dev-addr,len , with current-device set to the -\ node in question. "action-acf" can perform arbitrary tests -\ on the node to determine if that node is appropriate for -\ the action that it wished to undertake. - : test-subtree ( dev-addr,len -- ) current-device >r ( dev-addr,len r: phandle ) - find-device ( r: phandle xt ) - ['] most-tests ['] (search-preorder) catch 2drop ( r: phandle xt ) + find-device ( r: phandle ) + ['] most-tests ['] (search-preorder) catch 2drop ( r: phandle ) r> push-device ( ) ;
