Author: wmb Date: Wed Aug 31 10:21:10 2011 New Revision: 2491 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2491
Log: ARM - Added some comments to ARM multiplication code words. No functional change.
Modified: cpu/arm/muldiv.fth
Modified: cpu/arm/muldiv.fth ============================================================================== --- cpu/arm/muldiv.fth Wed Aug 31 10:19:47 2011 (r2490) +++ cpu/arm/muldiv.fth Wed Aug 31 10:21:10 2011 (r2491) @@ -208,23 +208,23 @@ c;
code fm/mod ( d.dividend s.divisor -- s.rem s.quot ) - mov r3,tos - mov r2,tos,asr #0 \ sign extend divisor - pop r0,sp - pop r1,sp - stmdb sp!,{r8,r9} + mov r3,tos \ r3:divisor.low + mov r2,tos,asr #0 \ r2:divisor.high (sign extended) + pop r0,sp \ r0:dividend.high + pop r1,sp \ r1:dividend.low + stmdb sp!,{r8,r9} \ save r8 and r9 cmp r0,#0 - < if + < if \ negative dividend? rsbs r1,r1,#0 - rsc r0,r0,#0 + rsc r0,r0,#0 \ r0,r1: abs(dividend) cmp r2,#0 - < if + < if \ negative divisor? rsbs r3,r3,#0 - rsc r2,r2,#0 + rsc r2,r2,#0 \ r2,r3: abs(divisor) bl 'code (u64division) rsbs r1,r1,#0 - rsc r0,r0,#0 - else + rsc r0,r0,#0 \ negate remainder for floored division + else \ nonnegative divisor mov r8,r2 mov r9,r3 bl 'code (u64division)
