Author: wmb Date: Sat Nov 24 01:33:25 2012 New Revision: 3456 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3456
Log: XO-4 - Added device node for HDMI EDID reading.
Modified: cpu/arm/olpc/gpio-i2c.fth
Modified: cpu/arm/olpc/gpio-i2c.fth ============================================================================== --- cpu/arm/olpc/gpio-i2c.fth Fri Nov 23 05:40:16 2012 (r3455) +++ cpu/arm/olpc/gpio-i2c.fth Sat Nov 24 01:33:25 2012 (r3456) @@ -110,4 +110,56 @@ : open ( -- flag ) true ; : close ( -- ) ; finish-device + +[ifdef] hdmi-sda-gpio# + new-device + " hdmi-i2c" device-name + " i2c-gpio" +compatible + 1 " #address-cells" integer-property + 1 " #size-cells" integer-property + : encode-unit ( phys.. -- str ) push-hex (u.) pop-base ; + : decode-unit ( str -- phys.. ) push-hex $number if 0 then pop-base ; + + 0 0 encode-bytes + hdmi-sda-gpio# 0 encode-gpio + hdmi-scl-gpio# 0 encode-gpio + " gpios" property + + h# 50 instance value slave-address + : set-address ( slave -- ) to slave-address ; + : smb-setup + 1 to smb-dly-us hdmi-scl-gpio# to smb-clock-gpio# + hdmi-sda-gpio# to smb-data-gpio# + slave-address to smb-slave + ; + \ Since this I2C bus is dedicated to HDMI, we save space by + \ implementing only the methods that HDMI DDC uses + : reg-b@ ( reg# -- b ) smb-setup smb-byte@ ; + : reg-b! ( b reg# -- ) smb-setup smb-byte! ; + : i2c-read ( adr len reg# -- ) smb-setup smb-read ; + : open ( -- flag ) true ; + : close ( -- ) ; + + new-device + " hdmi-ddc" device-name + h# 50 1 reg + : close ( -- ) ; + h# 100 buffer: hdmi-edid + + : get-edid ( -- adr len ) + hdmi-edid h# 100 0 " i2c-read" $call-parent + hdmi-edid h# 100 + ; + : open ( -- okay? ) + my-unit " set-address" $call-parent + hdmi-edid h# 100 0 " i2c-read" ['] $call-parent catch if + 2drop 3drop false + else + true + then + ; + : edid$ ( -- adr len ) hdmi-edid h# 100 ; + finish-device + finish-device +[then] device-end
