Author: wmb Date: 2008-08-20 10:00:54 +0200 (Wed, 20 Aug 2008) New Revision: 885
Modified: cpu/x86/pc/neptune/gpioinit.fth cpu/x86/pc/neptune/msrinit.fth cpu/x86/pc/neptune/romreset.bth cpu/x86/pc/neptune/vsapci.fth Log: Neptune - enable UART2.
Modified: cpu/x86/pc/neptune/gpioinit.fth =================================================================== --- cpu/x86/pc/neptune/gpioinit.fth 2008-08-20 02:03:20 UTC (rev 884) +++ cpu/x86/pc/neptune/gpioinit.fth 2008-08-20 08:00:54 UTC (rev 885) @@ -35,8 +35,8 @@ : gpio-init ( -- ) h# 0000 h# 1090 pl! h# c802 h# 1010 pl! \ Output AUX1 h# 0000 h# 1094 pl! h# 100 h# 1014 pl! \ Output AUX2 - h# 0900 h# 1084 pl! h# c91a h# 1004 pl! \ Output Enable - h# 1600 h# 10a0 pl! h# f6f5 h# 1020 pl! \ Input Enable + h# 0900 h# 1084 pl! h# c912 h# 1004 pl! \ Output Enable + h# 1600 h# 10a0 pl! h# f6e5 h# 1020 pl! \ Input Enable h# 1200 h# 10b4 pl! h# c604 h# 1034 pl! \ Input AUX1
h# 0000 h# 10a4 pl! h# 3081 h# 1024 pl! \ Input Invert (Int lines)
Modified: cpu/x86/pc/neptune/msrinit.fth =================================================================== --- cpu/x86/pc/neptune/msrinit.fth 2008-08-20 02:03:20 UTC (rev 884) +++ cpu/x86/pc/neptune/msrinit.fth 2008-08-20 08:00:54 UTC (rev 885) @@ -224,7 +224,7 @@ \ msr: 5140.001c 00000000.00000777. \ NANDF_CTL - default msr: 5140.001f 00000000.00000011. \ KEL_CTRL msr: 5140.0020 00000000.bb350a00. \ IRQM_YLOW - msr: 5140.0021 00000000.04000000. \ IRQM_YHIGH + msr: 5140.0021 00000000.34000000. \ IRQM_YHIGH msr: 5140.0022 00000000.00002222. \ IRQM_ZLOW \ msr: 5140.0023 00000000.600aa5b2. \ IRQM_ZHIGH \ teo was here
Modified: cpu/x86/pc/neptune/romreset.bth =================================================================== --- cpu/x86/pc/neptune/romreset.bth 2008-08-20 02:03:20 UTC (rev 884) +++ cpu/x86/pc/neptune/romreset.bth 2008-08-20 08:00:54 UTC (rev 885) @@ -67,16 +67,21 @@ \ enable GPIO 8 to OUT AUX1, 9 to IN_AUX1 100 dup 1004 port-wl 1010 port-wl \ GPIOL_OUTPUT_ENABLE, GPIOL_OUT_AUX1_SELECT 200 dup 1020 port-wl 1034 port-wl \ GPIOL_INPUT_ENABLE, GPIOL_IN_AUX1_SELECT + \ enable GPIO 4 to OUT AUX1, 3 to IN_AUX1 + 010 dup 1004 port-wl 1010 port-wl \ GPIOL_OUTPUT_ENABLE, GPIOL_OUT_AUX1_SELECT + 008 dup 1020 port-wl 1034 port-wl \ GPIOL_INPUT_ENABLE, GPIOL_IN_AUX1_SELECT
- \ set address to 3f8 51400014 rmsr \ MDD_LEG_IO - h# 00007.0000 # ax or + h# 00007.0000 # ax or \ set address to 3f8 for COM1 + h# 00050.0000 # ax or \ set address to 2f8 for COM2 51400014 wmsr
00000000.00000001. 5140003A set-msr \ SOFTRESET->MDD_UART1_CONF 00000000.00000012. 5140003A set-msr \ DEVEN | EN_BANKS -> MDD_UART1_CONF
+ 00000000.00000001. 5140003E set-msr \ SOFTRESET->MDD_UART2_CONF + 00000000.00000012. 5140003E set-msr \ DEVEN | EN_BANKS -> MDD_UART2_CONF
\ uart_init,serial.c \ This is a garden-variety 8250 UART setup sequence
Modified: cpu/x86/pc/neptune/vsapci.fth =================================================================== --- cpu/x86/pc/neptune/vsapci.fth 2008-08-20 02:03:20 UTC (rev 884) +++ cpu/x86/pc/neptune/vsapci.fth 2008-08-20 08:00:54 UTC (rev 885) @@ -169,7 +169,8 @@ ;
: preassigned-pci-slot? ( config-adr -- flag ) - drop true +\ drop true + d# 11 rshift h# 1fff and dup h# f = swap 1 = or ;
: config-setup ( a1 -- a2 special? )
