Author: wmb Date: Thu Dec 8 13:43:12 2011 New Revision: 2747 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2747
Log: EXC7200 touchscreen driver - mouse compatibility.
Modified: cpu/arm/olpc/exc7200-touchscreen.fth
Modified: cpu/arm/olpc/exc7200-touchscreen.fth ============================================================================== --- cpu/arm/olpc/exc7200-touchscreen.fth Thu Dec 8 13:43:07 2011 (r2746) +++ cpu/arm/olpc/exc7200-touchscreen.fth Thu Dec 8 13:43:12 2011 (r2747) @@ -4,13 +4,37 @@ 0 0 " 4,8" " /twsi" begin-package my-space encode-int my-address encode-int encode+ " reg" property " touchscreen" name + +0 value screen-w +0 value screen-h + : open ( -- okay? ) my-unit " set-address" $call-parent true \ Read once to prime the interrupt d# 10 " get" $call-parent 4drop 4drop 2drop + " dimensions" $call-screen to screen-h to screen-w ; : close ( -- ) ; -: get-touch? ( -- false | x y z down? contact# true ) + +h# 7fff constant touchscreen-max-x +h# 7fff constant touchscreen-max-y + +: invert-x ( x -- x' ) touchscreen-max-x swap - ; +: invert-y ( y -- y' ) touchscreen-max-y swap - ; + +: scale-x ( x -- x' ) + invert-x + screen-w touchscreen-max-x */ +; +: scale-y ( y -- y' ) + invert-y + screen-h touchscreen-max-y */ +; + +\ Try to receive a mouse report packet. If one arrives within +\ 20 milliseconds, return true and the decoded information. +\ Otherwise return false. +: pad? ( -- false | x y z down? contact# true ) d# 99 gpio-pin@ if false exit then d# 10 " get" $call-parent ( 4 flags xlo xhi ylo yhi zlo zhi 0 0 ) 2drop bwjoin >r bwjoin >r bwjoin >r ( 4 flags r: z y x ) @@ -21,12 +45,26 @@ r> r> r> 4drop false exit ( -- false ) then ( flags r: z y x )
- r> r> r> 3 roll ( x y z flags ) + r> scale-x ( flags x' r: z y ) + r> scale-y ( flags x y' r: z ) + + r> 3 roll ( x y z flags ) dup 1 and 0<> ( x y z flags down? ) swap 2 rshift h# 1f and ( x y z down? contact# ) true ( x y z down? contact# true ) ; - +true value absolute? +: stream-poll? ( -- false | x y buttons true ) + pad? if ( x y z down? contact# ) + 0= if ( x y z down? ) + nip 1 and true ( x y buttons true ) + else ( x y z down? ) + 4drop false ( false ) + then ( false | x y buttons true ) + else ( ) + false ( false ) + then ( false | x y buttons true ) +;
h# f800 constant red h# 07e0 constant green @@ -40,10 +78,8 @@ variable pixcolor
h# 4 value y-offset -0 value screen-w -0 value screen-h -0 value /line -2 value /pixel +\ 0 value /line +\ 2 value /pixel
variable ptr @@ -66,30 +102,6 @@ show-packets ;
-h# 7fff constant touchscreen-max-x -h# 7fff constant touchscreen-max-y - -: invert-x ( x y -- x' y ) touchscreen-max-x rot - swap ; -: invert-y ( x y -- x y' ) touchscreen-max-y swap - ; - -: scale-xy ( x y -- x' y' ) - invert-x invert-y - swap screen-w touchscreen-max-x */ - swap screen-h touchscreen-max-y */ -; - -\ Try to receive a mouse report packet. If one arrives within -\ 20 milliseconds, return true and the decoded information. -\ Otherwise return false. -: pad? ( -- false | x y z down? contact# true ) - get-touch? if ( x dy buttons ) - 2>r >r scale-xy r> 2r> ( x' y' z down? contact# ) - true - else - false - then -; - \ Display raw data from the device, stopping when a key is typed. : show-pad ( -- ) begin @@ -133,9 +145,10 @@ then ( x y ) ;
+: targets? ( -- flag ) true ; \ Used to be "final-test?" + : track-init ( -- ) - " dimensions" $call-screen to screen-h to screen-w - screen-ih package( bytes/line )package to /line +\ screen-ih package( bytes/line )package to /line load-base ptr ! ;
@@ -147,13 +160,13 @@
: background ( -- ) black 0 0 screen-w screen-h fill-rectangle-noff - final-test? if + targets? if false to left-hit? false to right-hit? draw-left-target draw-right-target else - 0 d# 27 at-xy ." Touchscreen test. Type a key to exit" cr + 0 d# 27 at-xy ." Touchscreen test. Hit both targets to exit" cr then ;
@@ -185,7 +198,7 @@
\ dup 5 and 5 = if background load-base ptr ! then
- final-test? if ( x y ) + targets? if ( x y ) ?hit-target ( x y ) then ( x y )
@@ -208,7 +221,7 @@
false value selftest-failed? \ Success/failure flag for final test mode : exit-test? ( -- flag ) - final-test? if ( ) + targets? if ( ) \ If the targets have been hit, we exit with successa left-hit? right-hit? and if ( ) false to selftest-failed? ( ) @@ -236,6 +249,8 @@ then ;
+: flush-touchpad ( -- ) begin pad? while 2drop 3drop repeat ; + : selftest ( -- error? ) open 0= if ." Touchscreen open failed" true exit @@ -248,7 +263,7 @@ \ Being able to open the touchpad is good enough in SMT mode smt-test? if close false exit then
- final-test? 0= if + targets? 0= if ." Touchscreen test will start in 4 seconds" cr d# 4000 ms then @@ -259,7 +274,7 @@ begin key? while key drop repeat
\ Consume already-queued trackpad events to prevent premature exit - begin pad? while 2drop 3drop repeat + flush-touchpad
background begin @@ -267,10 +282,12 @@ if track then exit-test? until
+ flush-touchpad + close cursor-on page - final-test? if selftest-failed? else false then + targets? if selftest-failed? else false then ;
