Author: wmb Date: 2009-11-13 23:40:37 +0100 (Fri, 13 Nov 2009) New Revision: 1472
Modified: cpu/x86/pc/olpc/via/startgfxrestore.fth Log: OLPC trac 9671 - restore video state to 24bpp mode. Also fixed a bug that appeared only in brown-bag versions a15p-r, in which the system crashed on resume.
Modified: cpu/x86/pc/olpc/via/startgfxrestore.fth =================================================================== --- cpu/x86/pc/olpc/via/startgfxrestore.fth 2009-11-13 20:47:00 UTC (rev 1471) +++ cpu/x86/pc/olpc/via/startgfxrestore.fth 2009-11-13 22:40:37 UTC (rev 1472) @@ -36,8 +36,6 @@ 80 17 crt-clr \ Assert reset while programming geometry
crtc-table - 30 36 ireg \ Turn off primary DAC to save power - d7 50 ireg \ Htotal low af 51 ireg \ Hdisplay low af 52 ireg \ Hblank low @@ -45,8 +43,8 @@ 24 54 ireg \ Hblank, Hblankend overflow 44 55 ireg \ Htotal and hdisplay overflow \ b7 56 ireg \ Hsync low - b5 56 ireg \ Hsync low - bd 57 ireg \ Hsyncend low + b6 56 ireg \ Hsync low + be 57 ireg \ Hsyncend low 8f 58 ireg \ Vtotal low 83 59 ireg \ Vdisplay low 83 5a ireg \ Vblank low @@ -54,24 +52,50 @@ 9b 5c ireg \ Hsync,Hsyncend,Vblank,Vblankend overflow 1b 5d ireg \ Hblankend, Hsync, Vtotal, Vdisplay overflow 88 5e ireg \ Vsync low - 6a 5f ireg \ Vsyncend all and Vsync overflow + 6e 5f ireg \ Vsyncend all and Vsync overflow
00 62 ireg \ Starting address 00 63 ireg \ Starting address 00 64 ireg \ Starting address
- 96 65 ireg \ Fetch count (67 overflow already set above) - 2c 66 ireg \ Offset (frame buffer pitch) low (67 overflow already set above) - 51 67 ireg \ Color depth - 16bpp ([7:6] = 10) - no interlace ([5] = 0), various overflow bits + 2c 65 ireg \ Fetch count (67 overflow already set above) + 58 66 ireg \ Offset (frame buffer pitch) low (67 overflow already set above) + d6 67 ireg \ Color depth - 32bpp ([7:6] = 11) - no interlace ([5] = 0), various overflow bits f0 68 ireg \ Display queue depth c8 6a ireg \ Enable secondary display 00 6b ireg \ Disable simultaneous display, IGA2 on, IGA2 screen enable not slaved to IGA1
00 6c ireg \ VCK source from PLL output clock, LCKCK PLL source from X1 pin
- 00 71 ireg \ Offset overflow - 00 79 ireg \ LCD scaling off - + ff 6d ireg + 77 6e ireg + ef 6f ireg + 7f 70 ireg + + 7f 71 ireg \ Offset overflow + 2f 72 ireg + ef 73 ireg + e7 74 ireg + ee 75 ireg + 77 76 ireg + 00 77 ireg + 6f 78 ireg + 68 79 ireg \ LCD scaling off + 01 7a ireg \ LCD Scaling Parameter 1 + 02 7b ireg \ LCD Scaling Parameter 2 + 03 7c ireg \ LCD Scaling Parameter 3 + 04 7d ireg \ LCD Scaling Parameter 4 + 07 7e ireg \ LCD Scaling Parameter 5 + 0A 7f ireg \ LCD Scaling Parameter 6 + 0D 80 ireg \ LCD Scaling Parameter 7 + 13 81 ireg \ LCD Scaling Parameter 8 + 16 82 ireg \ LCD Scaling Parameter 9 + 19 83 ireg \ LCD Scaling Parameter 10 + 1C 84 ireg \ LCD Scaling Parameter 11 + 1D 85 ireg \ LCD Scaling Parameter 12 + 1E 86 ireg \ LCD Scaling Parameter 13 + 1F 87 ireg \ LCD Scaling Parameter 14 + 60 88 ireg \ LVDS sequential 01 8a ireg \ LCD adjust LP 08 94 ireg \ Expire number @@ -108,12 +132,12 @@
\ legacy-settings seq-table - 00 00 ireg \ Reset sequencer +\ 00 00 ireg \ Reset sequencer - don't touch this register, it makes the system reset in this context 01 01 ireg \ 8/9 timing 0f 02 ireg \ Enable map planes 00 03 ireg \ Character map select 06 04 ireg \ Extended memory present - 03 00 ireg \ Release reset bits +\ 03 00 ireg \ Release reset bits - don't touch this register, it makes the system reset in this context 00 0a ireg \ Cursor start 00 0b ireg \ Cursor end 00 0e ireg \ Cursor loc @@ -166,7 +190,7 @@ end-table
crtc-table - 01 36 ireg \ Enable PCI power management control + 31 36 ireg \ Enable PCI power management control, primary DAC off 34 37 ireg \ DAC power savings end-table
