Author: rsmith Date: 2009-08-19 20:34:36 +0200 (Wed, 19 Aug 2009) New Revision: 1301
Modified: cpu/x86/pc/olpc/rtcwake.fth Log: OLPC: Make the ec wakcup tests exit based on a specific keypress (currently 'x') rather than just on any key. Also print out the value of any keypress we receive during the test.
Modified: cpu/x86/pc/olpc/rtcwake.fth =================================================================== --- cpu/x86/pc/olpc/rtcwake.fth 2009-08-19 03:40:15 UTC (rev 1300) +++ cpu/x86/pc/olpc/rtcwake.fth 2009-08-19 18:34:36 UTC (rev 1301) @@ -69,20 +69,31 @@ key drop ;
+\ Check if the 'x' was pressed +: test-exit? + key? if + ." Key: " + key dup h# 78 = if -1 else 0 then + swap .x cr + else 0 + then +; + : autowack-test ( ms -- ) autowack-delay autowack-on 0 begin s - dup space .d (cr 1+ key? + dup space .d (cr 1+ + test-exit? until - ." Keypress Exit key= " - key . drop + drop autowack-off ;
\ for testing wakeups from the EC : wackup-test-ec ( ms -- ) + ." Press x to exit" cr d# 3000 autowack-delay \ At small ms delays the host can miss the SCI so this \ is the back up. 0 begin ( ms count ) @@ -90,10 +101,10 @@ ec-wackup ( count ms ) s swap dup ( ms count count ) - space .d (cr 1+ key? ( ms count+1 ) - until - ." Keypress Exit key= " - key . 2drop + space .d (cr 1+ + test-exit? ( ms count+1 ) + until ( ms count+1 ) + 2drop autowack-off ;
