Author: wmb Date: Sat Oct 1 21:53:08 2011 New Revision: 2563 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2563
Log: OLPC XO-1.75 - commented-out ODT turn off/on in self-refresh code; appears to be unnecessary based on testing of q4b10mp.rom .
Modified: cpu/arm/mmp2/dramrecal.fth
Modified: cpu/arm/mmp2/dramrecal.fth ============================================================================== --- cpu/arm/mmp2/dramrecal.fth Sat Oct 1 21:51:55 2011 (r2562) +++ cpu/arm/mmp2/dramrecal.fth Sat Oct 1 21:53:08 2011 (r2563) @@ -62,9 +62,11 @@ mov r1, #0x1 \ Block all data requests str r1, [r0, #0x7e0] \ SDRAM_CTRL14
+[ifdef] notdef2 ldr r2, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 orr r1, r2, #0x03000000 \ PAD_TERM_SWITCH_MODE: Termination disabled str r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 +[then]
mov r1, #0x40 \ Enter Self Refresh value str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 @@ -87,7 +89,9 @@ mov r1, #0x80 \ Exit Self Refresh value str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0
+[ifdef] notdef2 str r2, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 - restore previous value +[then]
[ifdef] notdef mov r1, #0x01000000 \ Chip select 0
