Author: wmb Date: 2009-08-09 05:34:40 +0200 (Sun, 09 Aug 2009) New Revision: 1288
Added: dev/usb2/device/net/pegasus.fth Modified: dev/usb2/device/net/common.fth dev/usb2/device/net/ethernet.fth dev/usb2/device/net/usbnet.bth dev/usb2/device/net/vendor.fth Log: USB network driver - Added PegasusII chip support.
Modified: dev/usb2/device/net/common.fth =================================================================== --- dev/usb2/device/net/common.fth 2009-08-09 03:30:55 UTC (rev 1287) +++ dev/usb2/device/net/common.fth 2009-08-09 03:34:40 UTC (rev 1288) @@ -30,6 +30,8 @@
0 value multi-packet? \ True if a single USB transaction can \ transfer multiple network packets, e.g. ax88772 +0 value length-header? \ True if 16-bit little-endian length header is + \ prefixed to outgoing frames (pegasus)
0 value residue \ Remaining bytes in the packet buffer 0 value pkt-adr \ Offset into the packet buffer
Modified: dev/usb2/device/net/ethernet.fth =================================================================== --- dev/usb2/device/net/ethernet.fth 2009-08-09 03:30:55 UTC (rev 1287) +++ dev/usb2/device/net/ethernet.fth 2009-08-09 03:34:40 UTC (rev 1288) @@ -65,6 +65,10 @@ ;
: copy-packet ( adr len -- len' ) + dup outbuf le-w! tuck outbuf 2 + swap move 2 + +; + +: copy-packet ( adr len -- len' ) dup multi-packet? if 4 + then ( adr len len' ) /outbuf > if ." USB Ethernet write packet too long" cr stop-nic abort then ( adr len )
@@ -74,9 +78,15 @@ dup outbuf c! invert outbuf 2 + c! ( adr len ) tuck outbuf 4 + swap move ( len ) 4 + ( len' ) - else ( adr len ) - tuck outbuf swap move ( len ) - then ( len ) + else + length-header? if ( adr len ) + dup outbuf le-w! ( adr len ) + tuck outbuf 2 + swap move ( len ) + 2 + ( len ) + else + tuck outbuf swap move ( len ) + then ( len ) + then ;
: write ( adr len -- actual )
Added: dev/usb2/device/net/pegasus.fth =================================================================== --- dev/usb2/device/net/pegasus.fth (rev 0) +++ dev/usb2/device/net/pegasus.fth 2009-08-09 03:34:40 UTC (rev 1288) @@ -0,0 +1,180 @@ +purpose: Pegasus II USB ethernet driver +\ See license at end of file + +headers + +1 value phyid + +h# f0 constant GET_REG +h# f1 constant SET_REG + +\ Select register definitions +: ec0 0 ; +: ec1 1 ; +: ec2 2 ; +: gpio10c h# 7e ; +: gpio32c h# 7f ; +: phya h# 25 ; +: phydl h# 26 ; +: phydh h# 27 ; +: phyac h# 28 ; + +: error? ( flag -- ) ?dup if ." usb error: " . cr abort then ; + +\ Read system registers + +: pg-control-get ( adr len idx value cmd -- ) + DR_IN DR_VENDOR or DR_DEVICE or swap control-get error? drop +; + +: pg-read-regs-into-inbuf ( len index -- ) + inbuf -rot ( adr len index ) 0 GET_REG pg-control-get ( actual ) +; + +\ Read registers into memory array +: pg-read-regs ( adr len index -- ) + over >r ( adr len index r: len ) + pg-read-regs-into-inbuf ( adr r: len ) + inbuf swap r> ( inbuf adr len ) + move +; + +\ Read `len'-byte integer value +: pg-read-reg ( index len -- u ) 0 inbuf ! swap pg-read-regs-into-inbuf inbuf @ ; +: pg-reg-c@ ( index -- u ) 1 pg-read-reg ; +: pg-reg-w@ ( index -- u ) 2 pg-read-reg ; +: pg-reg-@ ( index -- u ) 4 pg-read-reg ; + +\ Write system registers + +: pg-control-set ( adr len idx value cmd -- ) + DR_OUT DR_VENDOR or DR_DEVICE or swap control-set error? +; + +: pg-set-regs ( adr len index -- ) 2 pick @ SET_REG pg-control-set ; + +: pg-write-reg ( u index len -- ) + rot outbuf ! ( index len ) + outbuf swap rot ( adr len index ) + pg-set-regs +; + +: pg-reg-c! ( u index -- ) 1 pg-write-reg ; +: pg-reg-w! ( u index -- ) 2 pg-write-reg ; +: pg-reg-! ( u index -- ) 4 pg-write-reg ; + +\ Read and write PHY registers. These are read indirectly through +\ system registers. + +: pg-mii-start-read ( index -- ) + h# 40 or d# 24 lshift phyid or + phya pg-reg-! +; + +: pg-mii-start-write ( u index -- ) + d# 24 lshift swap d# 8 lshift or phyid h# 10 or + phyac pg-reg-! +; + +: pg-mii-done? ( -- ) phyac pg-reg-c@ h# 80 and 0<> ; +: pg-mii-wait-done ( -- ) begin pg-mii-done? until ; + +: pg-mii-execute-read ( index -- u ) pg-mii-start-read pg-mii-wait-done ; +: pg-mii-execute-write ( u index -- ) pg-mii-start-write pg-mii-wait-done ; + +: pg-mii-data@ ( -- ) phydl pg-reg-w@ ; + +: pg-mii@ ( index -- u ) pg-mii-execute-read pg-mii-data@ ; + +: pg-mii! ( u index -- ) pg-mii-execute-write ; + +\ initialization & interface + +: pg-get-mac-address ( -- adr len ) + mac-adr /mac-adr h# 10 pg-read-regs + mac-adr /mac-adr +; + +: pg-link-up? ( -- flag ) 1 pg-mii@ 4 and 0<> ; + +: pg-reset-mac ( -- ) 8 ec1 pg-reg-c! ; +: pg-mac-reset? ( -- ) ec1 pg-reg-c@ 8 and 0= ; + +: pg-init-mac ( -- ) + pg-reset-mac begin pg-mac-reset? until + h# 26 gpio32c pg-reg-c! + h# 26 gpio10c pg-reg-c! + h# 24 gpio10c pg-reg-c! + h# 26 gpio10c pg-reg-c! +; + +: setup-pegasus-II ( -- ) + 0 h# 1d pg-reg-c! \ reserved + 2 h# 7b pg-reg-c! \ internal phy control - enable phy +; + +: pg-sync-link-status ( -- ) + \ Delayed loop until link-up is detected. + 5 0 do pg-link-up? if unloop exit then d# 1000 ms loop +; + +: pg-init-nic ( -- ) + true to length-header? + init-buf + 1 set-config error? + pg-get-mac-address 2drop + pg-init-mac + setup-pegasus-II + pg-sync-link-status +; + +: pg-start-nic ( -- ) + \ force 100Mbps full-duplex + h# 0130c9 ec0 3 pg-write-reg +; + +: pg-stop-nic ( -- ) + 0 ec0 2 pg-write-reg +; + +\ Process the length header that's inlined after the frame +: pg-unwrap-msg ( adr len -- adr len ) + over + 4 - ( len-adr ) + le-w@ h# fff and ( len ) + 8 - ( len ) +; + +: init-pegasus ( -- ) + ['] pg-init-nic to init-nic + ['] pg-link-up? to link-up? + ['] pg-start-nic to start-nic + ['] pg-stop-nic to stop-nic + ['] pg-get-mac-address to get-mac-address + ['] pg-unwrap-msg to unwrap-msg +; + +: init ( -- ) init vid pid pegasus? if init-pegasus then ; + +\ LICENSE_BEGIN +\ Copyright (c) 2009 Luke Gorrie luke@bup.co.nz +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: dev/usb2/device/net/usbnet.bth =================================================================== --- dev/usb2/device/net/usbnet.bth 2009-08-09 03:30:55 UTC (rev 1287) +++ dev/usb2/device/net/usbnet.bth 2009-08-09 03:34:40 UTC (rev 1288) @@ -15,6 +15,7 @@ fload ${BP}/dev/usb2/device/net/vendor.fth \ Ethernet vendor/product id table fload ${BP}/dev/usb2/device/net/common.fth \ Ethernet common variables and routines fload ${BP}/dev/usb2/device/net/ax8817x.fth \ AX8817X device routines +fload ${BP}/dev/usb2/device/net/pegasus.fth \ PegasusII device routines fload ${BP}/dev/usb2/device/net/ethernet.fth \ USB ethernet driver
end0
Modified: dev/usb2/device/net/vendor.fth =================================================================== --- dev/usb2/device/net/vendor.fth 2009-08-09 03:30:55 UTC (rev 1287) +++ dev/usb2/device/net/vendor.fth 2009-08-09 03:34:40 UTC (rev 1288) @@ -19,10 +19,20 @@ 05ac w, 1402 w, \ Apple here swap - constant /net-ax8817x-list
+create net-pegasus-list here + 050d w, 0121 w, \ Belkin F5D5050 + 07a6 w, 8515 w, \ ADMtek 8515 +here swap - constant /net-pegasus-list + : net-ax8817x? ( vid pid -- flag ) net-ax8817x-list /net-ax8817x-list find-vendor-product? ;
+: pegasus? ( vid pid -- flag ) + net-pegasus-list /net-pegasus-list find-vendor-product? +; + : usb-net? ( vid pid -- flag ) - net-ax8817x? + 2dup net-ax8817x? ( vid pid flag ) + -rot pegasus? or ( flag ) ;
