Author: wmb Date: Wed Mar 21 23:15:39 2012 New Revision: 2910 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2910
Log: Debugger - factored (trace so it's not so crazy long, and cleaned up a few minor glitches.
Modified: forth/lib/debug.fth
Modified: forth/lib/debug.fth ============================================================================== --- forth/lib/debug.fth Wed Mar 21 23:14:01 2012 (r2909) +++ forth/lib/debug.fth Wed Mar 21 23:15:39 2012 (r2910) @@ -37,8 +37,7 @@ variable step? step? on variable res headers -false value first-time? -d# 10 circular-stack: locations +false value redisplay?
: (debug) (s low-adr hi-adr -- ) unbug 1 cnt ! ip> ! <ip ! pnext @@ -47,7 +46,7 @@ slow-next? on then step? on - true is first-time? + true is redisplay? ; headerless : 'unnest (s pfa -- pfa' ) @@ -116,6 +115,7 @@ ." $ Display top of stack as adr,len text string" cr ." \ Display Forth return stack as numbers (like the data stack)" cr ." Q Quit: abandon execution of the debugged word" cr + ." V Visual: toggle between 2-D and scrolling" cr ; d# 24 constant cmd-column : to-cmd-column ( -- ) cmd-column to-column ; @@ -141,8 +141,6 @@ : save-result-loc ( -- ) #out @ to result-col #line @ to result-line ; : to-result-loc ( -- ) result-col result-line at-xy ;
-0 value rp-mark - \ set-package is a hook for Open Firmware. When Open Firmware is loaded, \ set-package should be set to a word that sets the active package to the \ package corresponding to the current instance. set-package is called @@ -165,72 +163,82 @@ variable hex-stack \ Show the data stack in hex? : save# ( -- ) #-buf /#buf - #buf-save d# 72 move hld @ hld-save ! ; : restore# ( -- ) #buf-save #-buf /#buf - d# 72 move hld-save @ hld ! ; +0 value the-ip +0 value the-rp : (.rs ( -- ) show-rstack @ 0= if exit then ." return-stack: " push-hex - rp0 @ rp@ - /n / - 6 do \ It appears that skipping the first 6 entries on the stack skips the debug goo on the rs - rp@ i /n * + @ . - loop + \ Skip the debugger's footprint on the return stack + rp0 @ the-rp 5 na+ ?do i @ . /n +loop pop-base ; -: (trace ( -- ) - first-time? if +: setup-scrolling-display ( -- ) + ??cr + the-ip <ip @ = if ." : " else ." Inside " then + <ip @ find-cfa .name +; +: setup-2d-display ( -- ) + page + d# 78 rmargin ! + .debug-short-help + ." Callers: " rp0 @ the-rp na1+ rslist kill-line cr + \ XXX the following is wrong when popping up + the-ip <ip @ = if + #line @ is stack-line \ So the initial stack is displayed in the right place + then + d# 40 rmargin ! + the-ip debug-see + cr + \ When popping up from an interior word, display the initial stack on + \ the line where the cursor will be. + the-ip <ip @ <> if + the-ip ip>position if ( col row ) + drop is stack-line ( ) + then + then +; +: setup-debug-display ( -- ) + redisplay? if scrolling-debug? if - ??cr - ip@ <ip @ = if ." : " else ." Inside " then - <ip @ find-cfa .name + setup-scrolling-display else - page - d# 78 rmargin ! - ." Callers: " rp0 @ rp@ na1+ rslist kill-line cr - \ XXX the following is wrong when popping up - ip@ <ip @ = if - #line @ is stack-line \ So the initial stack is displayed in the right place - then - d# 40 rmargin ! - ip@ debug-see - cr -\ ip@ <ip @ <> if -\ ip@ ip>position if ( col row ) -\ swap -\ is stack-line -\ then -\ #line @ is stack-line \ So the initial stack is displayed in the right place - \ then + setup-2d-display then 0 show-rstack ! - false is first-time? - rp@ is rp-mark + false is redisplay? then - - begin - step? @ if to-debug-window then +; +: show-debug-stack ( -- ) + scrolling-debug? if save# - scrolling-debug? if - cmd-column 2+ to-column + cmd-column 2+ to-column
- hex-stack @ if push-hex then - ." ( " .s \ Show data stack - hex-stack @ if pop-base then - show-rstack @ if (.rs then \ Show return stack - ." )" - restore# - - cr - ['] noop is indent - ip@ .token drop \ Show word name - ['] (indent) is indent - to-cmd-column - else - save-result-loc - show-partial-stack + hex-stack @ if push-hex then + ." ( " .s \ Show data stack + hex-stack @ if pop-base then + show-rstack @ if (.rs then \ Show return stack + ." )" + restore# + + cr + ['] noop is indent + the-ip .token drop \ Show word name + ['] (indent) is indent + to-cmd-column + else + save-result-loc + show-partial-stack
- ip@ ip-set-cursor - #line @ to stack-line - then - + the-ip ip-set-cursor + #line @ to stack-line + then +; +: debug-interact ( -- ) + save# + begin + step? @ if to-debug-window then + show-debug-stack step? @ key? or if step? on res off key dup bl < if drop bl then @@ -238,28 +246,35 @@ restore-window scrolling-debug? if reset-page then case - ascii D of ip@ token@ executer ['] (debug try endof \ Down - ascii U of rp@ ['] up1 try endof \ Up - ascii C of step? @ 0= step? ! true endof \ Continue - ascii F of + ascii D of the-ip token@ executer ['] (debug try endof \ Down + ascii U of the-rp ['] up1 try endof \ Up + ascii C of \ Continue + step? @ 0= step? ! + step? @ 0= if true to scrolling-debug? true to redisplay? then + true + endof + + ascii F of \ Forth cr ." Type 'resume' to return to debugger" cr set-package interact unset-package false - endof \ Forth - ascii G of debug-off cr exit endof \ Go - ascii H of cr .debug-long-help false endof \ Help - ascii R of cr rp0 @ rp@ na1+ (rstrace false endof \ RSTrace - ascii S of cr <ip @ body> (see) false endof \ See - ascii ? of cr .debug-short-help false endof \ Short Help + endof + ascii G of debug-off cr true endof \ Go + ascii H of cr .debug-long-help false endof \ Help + ascii R of cr rp0 @ the-rp na1+ (rstrace false endof \ RSTrace + ascii S of cr <ip @ body> (see) false endof \ See + ascii ? of cr .debug-short-help false endof \ Short Help ascii $ of space 2dup type cr to-cmd-column false endof \ String ascii Q of cr ." unbug" abort true endof \ Quit - ascii ( of ip@ set-<ip false endof - ascii < of ip@ ta1+ set-<ip 1 cnt ! false endof - ascii ) of ip@ ip> ! 1 cnt ! false endof - ascii * of ip@ find-cfa dup <ip ! 'unnest ip> ! false endof - ascii \ of show-rstack @ 0= show-rstack ! false endof - ascii X of hex-stack @ 0= hex-stack ! false endof - ascii V of scrolling-debug? 0= to scrolling-debug? - scrolling-debug? 0= if true to first-time? then false endof + ascii ( of the-ip set-<ip false endof + ascii < of the-ip ta1+ set-<ip 1 cnt ! false endof + ascii ) of the-ip ip> ! 1 cnt ! false endof + ascii * of the-ip find-cfa dup <ip ! 'unnest ip> ! false endof + ascii \ of show-rstack @ 0= show-rstack ! false endof \ toggle return stack display + ascii X of hex-stack @ 0= hex-stack ! false endof \ toggle heX stack display + ascii V of \ toggle Visual (2D) mode + scrolling-debug? 0= to scrolling-debug? + scrolling-debug? 0= if true to redisplay? then false + endof ( default ) true swap endcase else @@ -267,11 +282,17 @@ then until restore# - scrolling-debug? 0= if to-result-loc then - ip@ token@ dup ['] unnest = swap ['] exit = or if - cr true is first-time? +; +: (trace ( -- ) + ip@ to the-ip + rp@ to the-rp + setup-debug-display + debug-interact +\ scrolling-debug? 0= if to-result-loc then + the-ip token@ dup ['] unnest = swap ['] exit = or if + cr true is redisplay? then - pnext + slow-next? @ if pnext then ; ' (trace 'debug token!
