Author: quozl Date: Mon Oct 29 21:34:26 2012 New Revision: 3392 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3392
Log: spiflash - identify another second source parts by JEDEC ID rather than the short ID alone
Modified: dev/olpc/spiflash/spiflash.fth
Modified: dev/olpc/spiflash/spiflash.fth ============================================================================== --- dev/olpc/spiflash/spiflash.fth Mon Oct 29 06:39:46 2012 (r3391) +++ dev/olpc/spiflash/spiflash.fth Mon Oct 29 21:34:26 2012 (r3392) @@ -307,13 +307,16 @@ \ ST, Spansion, and WinBond h# 13 of ['] common-write 1mb-flash endof h# 34 of ['] common-write 1mb-flash - \ jedec-id h# 3425c2 = if 2mb-flash then \ MXIC 25E8035 + \ jedec-id h# 3425c2 = if 1mb-flash then \ MXIC 25E8035 endof \ the SST part with its unique auto-increment address writing scheme h# bf of ['] sst-write 1mb-flash endof h# 14 of ['] common-write 1mb-flash jedec-id h# 1540c8 = if 2mb-flash then \ XO-4 B1 endof + h# 15 of ['] common-write 1mb-flash + jedec-id h# 1525c2 = if 2mb-flash then \ MXIC25L1635E + endof h# 35 of ['] common-write 2mb-flash endof \ W25Q16CV 3525c2 ( default ) ." Bad SPI FLASH ID " dup . cr ['] null-write swap endcase ( writer ) @@ -331,6 +334,7 @@ spi-id# case h# 13 of ." type 13 - Spansion, Winbond, or ST" endof h# 14 of ." type 14" endof + h# 15 of ." type 15 - MXIC25L1635E" endof h# 34 of ." type 34 - Macronyx" endof h# 35 of ." type 35 - 2 MB" endof endcase
