Author: wmb Date: Fri Oct 12 00:53:24 2012 New Revision: 3362 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3362
Log: SDHCI - fixed ok copy int:\foo int:\bar which was hanging
Modified: dev/mmc/sdhci/slot.fth
Modified: dev/mmc/sdhci/slot.fth ============================================================================== --- dev/mmc/sdhci/slot.fth Thu Oct 11 09:50:31 2012 (r3361) +++ dev/mmc/sdhci/slot.fth Fri Oct 12 00:53:24 2012 (r3362) @@ -2,12 +2,22 @@
0 " #address-cells" integer-property 0 " #size-cells" integer-property +[ifdef] my-clock-on +0 value open-count +[then] + : open - [ifdef] my-clock-on my-clock-on [then] +[ifdef] my-clock-on + open-count 0= if my-clock-on then + open-count 1+ to open-count +[then] true ; : close - [ifdef] my-clock-off my-clock-off [then] +[ifdef] my-clock-off + open-count 1 = if my-clock-off then + open-count 1- 0 max to open-count +[then] ;
: r/w-blocks " r/w-blocks" $call-parent ;
