Author: wmb Date: Thu Dec 16 20:13:57 2010 New Revision: 2081 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2081
Log: OLPC trac #10547 - mouse driver was broken due to bad syntax for the unit address.
Modified: dev/i8042.fth dev/pci/isakbd.fth
Modified: dev/i8042.fth ============================================================================== --- dev/i8042.fth Thu Dec 16 07:40:34 2010 (r2080) +++ dev/i8042.fth Thu Dec 16 20:13:57 2010 (r2081) @@ -33,7 +33,13 @@
\ 0 means the keyboard port, 1 means the aux port : encode-unit ( n -- adr len ) if " aux" else " kbd" then ; -: decode-unit ( adr len -- n ) " aux" $= 0= if 0 else 1 then ; +: decode-unit ( adr len -- n ) + 2dup $number if ( adr len ) + " aux" $= 0= if 0 else 1 then ( n ) + else ( adr len n ) + nip nip ( n ) + then +;
\ Queues for distributing bytes sent from the two devices d# 100 constant /q
Modified: dev/pci/isakbd.fth ============================================================================== --- dev/pci/isakbd.fth Thu Dec 16 07:40:34 2010 (r2080) +++ dev/pci/isakbd.fth Thu Dec 16 20:13:57 2010 (r2081) @@ -12,7 +12,7 @@ finish-device
new-device - " " " 1" set-args + " " " aux" set-args fload ${BP}/dev/ps2mouse.fth \ d# 12 encode-int 3 encode-int encode+ " interrupts" property finish-device
