Author: quozl Date: Sat Nov 17 04:10:07 2012 New Revision: 3440 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3440
Log: OLPC XO-4 - touchscreen response timing estimation tweaks for 0.0.0.8
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Sat Nov 17 00:23:04 2012 (r3439) +++ cpu/arm/olpc/nn-touchscreen.fth Sat Nov 17 04:10:07 2012 (r3440) @@ -382,7 +382,7 @@
: test-os-axis ( axis -- ) h# 21 h# 02 h# ee 4 bytes-out - h# 21 d# 30 anticipate + h# 21 d# 60 anticipate pbuf 2+ c@ h# 21 <> abort" response other than open short"
pbuf d# 5 + ( addr ) @@ -442,7 +442,7 @@
: test-fss-axis ( axis -- ) d# 64 swap h# 0f h# 03 h# ee 5 bytes-out - h# 0f d# 20 anticipate + h# 0f d# 60 anticipate pbuf 2+ c@ h# 0f <> abort" response other than fixed signal strength" 8sp push-decimal @@ -473,7 +473,7 @@
: test-fss-axis-all ( axis power -- ) swap h# 0f h# 03 h# ee 5 bytes-out - h# 0f d# 20 anticipate + h# 0f d# 60 anticipate pbuf 2+ c@ h# 0f = if pbuf 4 + c@ 0 do ( ) pbuf 5 + i + c@
