Author: wmb Date: 2009-03-23 23:55:21 +0100 (Mon, 23 Mar 2009) New Revision: 1123
Added: cpu/x86/pc/olpc/HOWTO-keyjector Log: Added HOWTO-keyjector instructions.
Added: cpu/x86/pc/olpc/HOWTO-keyjector =================================================================== --- cpu/x86/pc/olpc/HOWTO-keyjector (rev 0) +++ cpu/x86/pc/olpc/HOWTO-keyjector 2009-03-23 22:55:21 UTC (rev 1123) @@ -0,0 +1,52 @@ +A keyjector is an intermediate firmware release that installs +additional customer-specific security keys in manufacturing data. +OLPC signs is so it can be auto-reflashed. When it starts, it inserts +the new keys, then replaces itself with a higher-rev firmware version +so it doesn't run again. + +The version number for the keyjector is between two "real" releases. +It has to be higher than any version number that might already exist +on the customer's target machines. For example, if the customer has +only q2e34 and earlier, the keyjector version might be q2e34x, and the +successor firmware might be q2e35. In the worst case, this means that +you would have to make a new real firmware release so there is a +successor (q2e35 in this example). + +The keyjector itself is built with an abbreviated release procedure, +within the existing build tree for the release right before the +successor. In the example, the keyjector would be build in the +existing tree for q2e34. + +The steps are: + +* Unpack the tar file containing the new keys into, for example, /home/wmb/Uruguay + +* Note the list of key names, e.g. d0 a1 o1 s1 t1 w1 + +$ cd /home/firmware/q2e34/openfirmware/cpu/x86/pc/olpc/build + +* Edit ../keyjector.bth : + +** Change the "macro: FW_MINOR " line to the keyjector's intermediate version number, e.g. 34x +** Changing lines like below to the right file and key names. + " /space/bios-crypto/build/k2.public" " s1" $add-dropin + +* Edit ../keyjector.fth : + +** In wrong-sku?, set the list of SKUs. This guards against "hijacking" of other country's laptops. +** In keyject-expired?, set an appropriate expiration date for the keyjector. +** In new-key-list$, set the key list. + +$ ./build keyject + +It should build really quickly, because it is using nearly all the same modules as the base build. + +* Verify the version number in the new file: + +** $ xxd q2e34x.rom | tail -4 + +* If you have to make a new "real" release so the keyjector has a successor, do so now. + +* Sign the keyjector, naming the .zip file "bootfw.zip". + +* Sign the successor firmware, name the .zip file "bootfw2.zip"
