Author: wmb Date: 2009-11-20 22:01:27 +0100 (Fri, 20 Nov 2009) New Revision: 1494
Modified: cpu/ppc/fb8-ops.fth cpu/ppc/kerncode.fth ofw/termemu/fb8.fth Log: PowerPC - added PPC versions of new display primitives.
Modified: cpu/ppc/fb8-ops.fth =================================================================== --- cpu/ppc/fb8-ops.fth 2009-11-19 17:19:33 UTC (rev 1493) +++ cpu/ppc/fb8-ops.fth 2009-11-20 21:01:27 UTC (rev 1494) @@ -43,6 +43,84 @@ addi sp,sp,1cell c;
+\ Invert foreground and background colors within a rectangular region +code fb16-invert ( adr width height bytes/line fg-color bg-color -- ) + \ bg-color in tos + lwz t4,0(sp) \ fg-color in t4 + lwzu t0,1cell(sp) \ bytes/line in scr + lwzu t2,1cell(sp) \ height in t1 (outer loop index, >0) + lwzu t1,1cell(sp) \ width in t2 (inner loop index, >0) + lwzu t3,1cell(sp) \ adr in sc3 (starting address) + + mfspr t6,ctr \ Save counter + + subf t0,t1,t0 \ Account for inner loop incrementing + addi t3,t3,-2 \ Account for inner loop incrementing + + begin \ Outer loop + mtspr ctr,t1 \ Starting width value + begin \ Inner loop + lhzu t5,2(t3) \ read halfword + cmp 0,0,t5,tos \ Background? + = if + mr t5,t4 \ Set to foreground + else + cmp 0,0,t5,t4 \ Foreground? + = if + mr t5,tos \ Set to background + then + then + sth t5,0(t3) \ store halfword + countdown \ End inner loop when width=0 + + addic. t2,t2,-1 \ decrement height until =0 + add t3,t3,t0 \ increment adr to next line + = until \ End outer loop when height=0 + + mtspr ctr,t6 \ Restore counter + lwzu tos,1cell(sp) \ Clean up stack + addi sp,sp,1cell +c; + +\ Invert foreground and background colors within a rectangular region +code fb32-invert ( adr width height bytes/line fg-color bg-color -- ) + \ bg-color in tos + lwz t4,0(sp) \ fg-color in t4 + lwzu t0,1cell(sp) \ bytes/line in scr + lwzu t2,1cell(sp) \ height in t1 (outer loop index, >0) + lwzu t1,1cell(sp) \ width in t2 (inner loop index, >0) + lwzu t3,1cell(sp) \ adr in sc3 (starting address) + + mfspr t6,ctr \ Save counter + + subf t0,t1,t0 \ Account for inner loop incrementing + addi t3,t3,-4 \ Account for inner loop incrementing + + begin \ Outer loop + mtspr ctr,t1 \ Starting width value + begin \ Inner loop + lwzu t5,4(t3) \ read word + cmp 0,0,t5,tos \ Background? + = if + mr t5,t4 \ Set to foreground + else + cmp 0,0,t5,t4 \ Foreground? + = if + mr t5,tos \ Set to background + then + then + stw t5,0(t3) \ store word + countdown \ End inner loop when width=0 + + addic. t2,t2,-1 \ decrement height until =0 + add t3,t3,t0 \ increment adr to next line + = until \ End outer loop when height=0 + + mtspr ctr,t6 \ Restore counter + lwzu tos,1cell(sp) \ Clean up stack + addi sp,sp,1cell +c; + \ Draws a character from a 1-bit-deep font into an 8-bit-deep frame buffer \ Assumptions: Fontbytes is 2; 0 < width <= 16 \ Fontadr is divisible by 2 @@ -106,6 +184,132 @@ addi sp,sp,4 c;
+\ Draws a character from a 1-bit-deep font into a 16-bit-deep frame buffer +\ Assumptions: Fontbytes is 2; 0 < width <= 16 +\ Fontadr is divisible by 2 +code fb16-paint +( fontadr fontbytes width height screenadr bytes/line fg-color bg-color -- ) + \ tos already there \ bg-color in tos + lwz t9,0(sp) \ fg-color in t9 + lwzu t2,1cell(sp) \ Bytes/line - bytes per scan line + lwzu t3,1cell(sp) \ Screenadr - start address in frame buffer + lwzu t4,1cell(sp) \ Height - character height in pixels + lwzu t5,1cell(sp) \ Width - character width in pixels (bytes) + lwzu t6,1cell(sp) \ Fontbytes - bytes per font line + lwzu t7,1cell(sp) \ Fontadr - start adr of this char in font table + + addi t3,t3,-2 \ Account for pre-incrementing + subf t2,t5,t2 \ Account for inner loop incrementing + mfspr t8,ctr \ Save counter + + addi r0,r0,8 \ Constant 8 (pixels/font-byte), needed below + + + begin \ Outer loop - for all scan lines in char + lbz t0,0(t7) \ Up to 8 font bits into scr + rlwinm t0,t0,23,1,8 \ Align almost to high part of word so that + \ one more shift will affect the sign bit + + mr t1,t5 \ Reset width counter for the new scan line + + ahead \ Branch down to end of loop + begin + + cmpi 0,0,t1,8 + < if + mtspr ctr,t1 \ Set count + subf t1,t1,t1 \ Width is exhausted + else + mtspr ctr,r0 \ Max inner loop count is 8 + addi t1,t1,-8 \ Reduce width by 8 + then + + begin \ Inner loop - for each pixel in a font byte + add. t0,t0,t0 \ Shift next pixel bit to top position + 0< if + sthu t9,2(t3) \ Write foreground color to framebuffer + else + sthu tos,2(t3) \ Write background color to framebuffer + then + countdown \ Repeat until width count = 0 + + but then + cmpi 0,0,t1,0 + = until + + add t7,t7,t6 \ Next scan line in font table + addic. t4,t4,-1 \ Decrement height counter + add t3,t3,t2 \ Increment frame buffer addr to next line + = until \ Repeat until height count = 0 + + mtspr ctr,t8 \ Restore counter + lwzu tos,4(sp) \ Clean up stack + addi sp,sp,4 +c; + +\ Draws a character from a 1-bit-deep font into a 32-bit-deep frame buffer +\ Assumptions: Fontbytes is 2; 0 < width <= 16 +\ Fontadr is divisible by 2 +code fb32-paint +( fontadr fontbytes width height screenadr bytes/line fg-color bg-color -- ) + \ tos already there \ bg-color in tos + lwz t9,0(sp) \ fg-color in t9 + lwzu t2,1cell(sp) \ Bytes/line - bytes per scan line + lwzu t3,1cell(sp) \ Screenadr - start address in frame buffer + lwzu t4,1cell(sp) \ Height - character height in pixels + lwzu t5,1cell(sp) \ Width - character width in pixels (bytes) + lwzu t6,1cell(sp) \ Fontbytes - bytes per font line + lwzu t7,1cell(sp) \ Fontadr - start adr of this char in font table + + addi t3,t3,-4 \ Account for pre-incrementing + subf t2,t5,t2 \ Account for inner loop incrementing + mfspr t8,ctr \ Save counter + + addi r0,r0,8 \ Constant 8 (pixels/font-byte), needed below + + + begin \ Outer loop - for all scan lines in char + lbz t0,0(t7) \ Up to 8 font bits into scr + rlwinm t0,t0,23,1,8 \ Align almost to high part of word so that + \ one more shift will affect the sign bit + + mr t1,t5 \ Reset width counter for the new scan line + + ahead \ Branch down to end of loop + begin + + cmpi 0,0,t1,8 + < if + mtspr ctr,t1 \ Set count + subf t1,t1,t1 \ Width is exhausted + else + mtspr ctr,r0 \ Max inner loop count is 8 + addi t1,t1,-8 \ Reduce width by 8 + then + + begin \ Inner loop - for each pixel in a font byte + add. t0,t0,t0 \ Shift next pixel bit to top position + 0< if + stwu t9,4(t3) \ Write foreground color to framebuffer + else + stwu tos,4(t3) \ Write background color to framebuffer + then + countdown \ Repeat until width count = 0 + + but then + cmpi 0,0,t1,0 + = until + + add t7,t7,t6 \ Next scan line in font table + addic. t4,t4,-1 \ Decrement height counter + add t3,t3,t2 \ Increment frame buffer addr to next line + = until \ Repeat until height count = 0 + + mtspr ctr,t8 \ Restore counter + lwzu tos,4(sp) \ Clean up stack + addi sp,sp,4 +c; + \ Very fast window move, for scrolling \ Similar to 'move', but only moves #move/line out of every 'bytes/line' bytes \ Assumes bytes/line is divisible by 8 (for double-long load/stores) @@ -123,7 +327,7 @@ 4 constant fbalign [then]
-code fb8-window-move ( src-start dst-start size bytes/line #move/line -- ) +code fb-window-move ( src-start dst-start size bytes/line #move/line -- ) \ tos=#move/line lwz t0,0(sp) \ t0=bytes/line lwzu t1,1cell(sp) \ t1=size
Modified: cpu/ppc/kerncode.fth =================================================================== --- cpu/ppc/kerncode.fth 2009-11-19 17:19:33 UTC (rev 1493) +++ cpu/ppc/kerncode.fth 2009-11-20 21:01:27 UTC (rev 1494) @@ -695,7 +695,40 @@
pop2 c; +code wfill (s start-adr count w -- ) + \ 16-bit data in tos + second-to-t0 \ count in t0 + third-to-t1 \ dst in t1 + + addi t1,t1,-2 \ Account for pre-increment + rlwinm t0,t0,31,1,31 \ Divide count by 2 + mfspr t2,ctr \ Save CTR + mtspr ctr,t0 + begin + sthu tos,2(t1) + countdown + mtspr ctr,t2
+ pop2 +c; + +code lfill (s start-adr count long -- ) + \ 32-bit data in tos + second-to-t0 \ count in t0 + third-to-t1 \ dst in t1 + + addi t1,t1,-1cell \ Account for pre-increment + rlwinm t0,t0,30,2,31 \ Divide count by 4 + mfspr t2,ctr \ Save CTR + mtspr ctr,t0 + begin + stwu tos,1cell(t1) + countdown + mtspr ctr,t2 + + pop2 +c; + code noop (s -- ) c;
code lowbyte (s n -- low ) andi. tos,tos,h#ff c;
Modified: ofw/termemu/fb8.fth =================================================================== --- ofw/termemu/fb8.fth 2009-11-19 17:19:33 UTC (rev 1493) +++ ofw/termemu/fb8.fth 2009-11-20 21:01:27 UTC (rev 1494) @@ -241,6 +241,7 @@ loop 2drop ( ) ;
+[ifdef] cursor-w [ifndef] fb8-merge : fb8-merge ( color bits dst-adr width -- ) bounds ?do ( color mask ) @@ -289,6 +290,7 @@ loop 4drop ; +[then]
headers : fb8-insert-characters ( #chars -- ) @@ -317,7 +319,9 @@ ['] fb8-invert to fb-invert ['] fill to fb-fill ['] fb8-paint to fb-paint +[ifdef] fb8-merge ['] fb8-merge to fb-merge +[then] ['] colors-8bpp to fb-16map endof
@@ -326,7 +330,9 @@ ['] fb16-invert to fb-invert ['] wfill to fb-fill ['] fb16-paint to fb-paint +[ifdef] fb16-merge ['] fb16-merge to fb-merge +[then] ['] colors-565 to fb-16map endof
@@ -335,7 +341,9 @@ ['] fb32-invert to fb-invert ['] lfill to fb-fill ['] fb32-paint to fb-paint +[ifdef] fb32-merge ['] fb32-merge to fb-merge +[then] ['] colors-32bpp to fb-16map endof endcase
