Author: wmb Date: Fri Apr 13 01:28:34 2012 New Revision: 2942 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2942
Log: OLPC XO-1.75 and XO-3 - changed EDI (SPI interface to EC) timing to account for rise time issue on MISO.
Modified: cpu/arm/olpc/bbedi.fth
Modified: cpu/arm/olpc/bbedi.fth ============================================================================== --- cpu/arm/olpc/bbedi.fth Mon Apr 9 05:10:42 2012 (r2941) +++ cpu/arm/olpc/bbedi.fth Fri Apr 13 01:28:34 2012 (r2942) @@ -103,7 +103,7 @@ loop ( b ) ; [else] -code edi-out0 ( byte -- ) +code edi-out ( byte -- ) mov r2,#8 mov r0,#0x200 \ MOSI mask set r1,`h# 19100 +io #` \ GPIO register address @@ -112,7 +112,9 @@ ands r3,tos,#0x80 \ Test bit
strne r0,[r1,#0x18] \ Set MOSI if bit is non0 + strne r0,[r1,#0x18] \ Set MOSI if bit is non0 \ Twice for delay - setup time to CLK streq r0,[r1,#0x24] \ Clr MOSI if bit is 0 + streq r0,[r1,#0x24] \ Clr MOSI if bit is 0 \ Twice for delay - setup time to CLK
str r4,[r1,#0x18] \ Set CLK str r4,[r1,#0x24] \ Clr CLK @@ -123,7 +125,7 @@
pop tos,sp c; -code edi-out ( byte -- ) +code edi-out1 ( byte -- ) mov r2,#8 mov r0,#0x200 \ MOSI mask set r1,`h# 19100 +io #` \ GPIO register address @@ -158,7 +160,7 @@
\ This delay is necessary to let the MMP2 GPIO pin clock in the \ data value. Without the delay, bit values get lost. - mov r7,#0x160 \ Delay spins + mov r7,#0x400 \ Delay spins begin decs r7,#1 0= until @@ -166,6 +168,11 @@ ldr r0,[r1] \ Read pin register str r0,[r3],#4 str r4,[r1,#0x24] \ Clr CLK + mov r7,#0x400 \ Delay spins + begin + decs r7,#1 + 0= until + ands r0,r0,#0x80 \ Test MISO bit incne tos,1 \ Set bit in byte
